The new skin is great, can't wait for the additional colors.
Couple of minor things I found:
I couldn't get the JTTPlugin to work at first. You need to update the .chm file's manual install to include copying the plugin to your RoadRunner path for those of us that don't use the installer.
I use key maps to navigate between menus (building some custom controls). For some reason I can no longer go directly to the Main menu skin using my "MAIN" keytbl.ini mapping from the other screens. Here's the scenario; I hit a key that maps to "AUDIO" and that works (loads to the Playlist screen) but then if I hit the key that maps to "MENU" nothing happens. Worked fine in the last beta.
*EDIT: Ignore the navigation issue I had another app running in the background that was hijacking my keystroke.
So far that's all I've seen....great work.
LinkBack URL
About LinkBacks
