View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #1521
    Newbie Major_Disaster's Avatar
    Oct 2006
    Current Version of Digital FX
    John,
    On your site it shows:
    DigitalFX 2.11
    Updated 04/19/07
    02:38 PM EST
    But on Post #1 it shows:
    Latest Version 2.22: 05/01/2007 12:10 AM EST
    Can you shed some light on this? I would love to get the lastest version.
  2. #1522
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Major_Disaster View Post
    John,
    DigitalFX 2.11
    Updated 04/19/07
    02:38 PM EST
    05/01 is the latest version, just forgot to update the page I guess, sorry for the confusion.
    My Fiero Build Thread
  3. #1523
    Oct 2006
    Visualizations
    I posed a question in post 1461 about the equalizer visualization. Any thoughts?
  4. #1524
    Jul 2004
    New Jersey
    OK, get ready to slap me or use a string of your favorite expletives... But after tons of reading I am daring enough to ask a Flash question.
    I am having an issue with the latest Digital FX / Road Runner install that sounds like what many others complain about, but not quite.
    The issue is only seen on the GPS Stats page, like below...
    It has two blue boxes and one white box where the gauges should be, but the gauges are fully functional... and there is never a spike in CPU usage. When I'm actually on the road, the compass and the number of satellites is dynamic, and the speedo works, too. So, the Flash is working, but the background or skin just isn't right.
    Thanks for creating and maintaining this skin, and I apologize if I am - but it seemed slightly different from what I have read. If it is the same old thing, feel free to ignore me and I'll get the point.
    Mostly Useless Info - Free Image Host
  5. #1525
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    /ignores squiggle star seventy seven star squiggle
    actually if it isn't transparent check that you have a) the latest roadrunner b) you have copied the contents of RR_Add-2-.ini which is on your desktop to rr.ini.
    if you have white boxes where flash stuff is embedded then update/downgrade your flash to version 8 (can't remember if it has been fixed to work with 9 yet, but anything less than 8 won't)
  6. #1526
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I have never seen the Visualization's do anything quite like that.... Hmmm... Check the help file, and also make sure you make the screensaver.ini file mentioned in there, as you should be seeing the burlwood background at the top as well, with the visu being overlayed over it.
    I would also check that you have the AVS visu's set up as well correctly, as it looks like nothing is actually loading.
    Quote Originally Posted by ~*77*~ View Post
    As for the way the gauges look in your screen capture, it is most definitely a flash issue. Read Enforcer's previous post, and give that a try. When flash is installed correctly, that problem should clear up for you.
  7. #1527
    Jul 2004
    New Jersey
    oh OH! You guys rock.
    All I did was download and run the stand alone Flash Player again and everything is good.
    Thanks! Not only for helping, but sparing me from the usual venom that noob questions get!
  8. #1528
    Newbie Niob's Avatar
    May 2007
    Norway
    HI.
    I use FreeFone and want to be able to see the phone status on the menu.skin and menu2.sin Så i add the future i like. And works fine. But only til i change the clock or logo. The it dissapear. So i guess there is a "default" somewhere that gets "restored" when i change settings. How do i solve this? Please help. Love the skin but want to be able to add some minor personal futures.
    Tnx for the greate work. Best skin i ever tested.
  9. #1529
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Niob View Post
    HI.
    You are exactly right. If you open the DigitalFX skin folder, in that folder are the default menu's for the different type of menu styles that get copied out of the subfolder to the main DigitalFX folder. You need to make the changes to each of the menu files in the subfolders there, or they will get over written when you change the menu style.
  10. #1530
    Jan 2007
    South Jersey, NJ
    John,
    Before my idiot question, just wanted to say; You're the man!
    Anyhow, you had the psd for the XM fav's up on johnwpb.com before the newest version. Is there a corresponding psd for the updated skin? I modified the old one with my fav xm channels and updated the channel images but the old psd template won't work real well with the new transparent skin Can you post the newer psd?
    Thanks again for all your work!
    -J
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
