View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #1701
    Jan 2007
    Quote Originally Posted by DeadlyAP1 View Post
    Also, and this is probably a problem outside of your skin, but I have had an issue with XM. If I am listening to MP3 when I shut car off (standby), when it resumes, I can hear the XM over the MP3 and need to go into the XM skin and then go back to the MP3 to stop the XM sound. If I am listening to XM when I shut down, there is no MP3 when I resume.
    I researched it some, and I have my mic setting muted on the volume control before I start RR. I also have the mic in set as the line to mute in RR config. Any suggestions?
    I am having this exact problem. I have to minimize the skin and manually turn the volume up on winamp or sometimes press the play button on winamp. Its weird. Im just now finding the time to start working the bugs out of my system and this is one of them.
  2. #1702
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Quote Originally Posted by esko View Post
    I just now realized that I don't have a RR*.exe in my DFX2.0 folder. The only one I have is the one that is RoadRunner.exe (650k)
    Can you post the correct one, or send to me via private message?
    I'd really appreciate it.
    Thanks for all your help!
    I also cant find any other roadrunner.exe other than the one that came with the rr download. Is there a place to get just that file?
    EDIT: I found it in the lastest download. Didnt realize I was even missing it.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  3. #1703
    Low Bitrate esko's Avatar
    Jun 2007
    Quote Originally Posted by redls1bird View Post
    It's part of the DFX.exe download. It is installed on the desktop after you install DFX.exe.
  4. #1704
    May 2007
    It seems I have a proble with iGuidance. Whenever I click GPS on the screen, it seems to launch a new instance of iGuidance. (I can see more and more of them through ALT+TAB). Since the previous instance is already using the GPS COM port, the new one will not work.
    Is there a setting somewhere I can change?
  5. #1705
    Jun 2007
    Quote Originally Posted by Toxic0n View Post
    I would normally say use the search button, but this happened to me as well. Change the GPS Window Name to iGuidance in the Road Runner Configuration file under the G.P.S button.
    That should fix the problem.
  6. #1706
    May 2007
    Thanks a lot, I will try that in a bit. BTW, I searched for "iGuidance instances" but it found a lot of threads that were not related to the problem.
  7. #1707
    May 2007
    Wohoo, that worked. This forum rocks!
    Now another newbie question, is there a way to remove unused button from the screen? i.e. Sat Radio or TV? Will I have to edit the flash files for this?
  8. #1708
    Raw Wave
    Jun 2002
    Virginia
    There's not really an easy way to remove or change buttons unless you have the PSDs (photoshop files), which John has said he won't be releasing.
  9. #1709
    Sep 2006
    Sabattus, ME
    I don't get why people can't use the search function, seriously it is not that hard.
    Yes indeed i am alive barely, my carPC literally blew up about 2 months ago. I started a new job at Johnson and Johnson so that has been taking up a lot of my time. I don't think i will be back in the carPC business for a while with me needing a new computer and that i still dont have a god damn touch screen. But you never know. Il check back when i get. Hope all is going well.
    CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
    Powered By Road Runner & DigitalFX Skin and Playlist Conveter
  10. #1710
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    ^^^ because the search function sucks! and a successful search depend on your search terms. If i notice 2 or 3 instances of iguidance popup when i press a button - what do i search for? iguidance? instances? iguidance instances? what?
    There are new members in that are answering the new members questions so leave it alone.
    This thread is at the point where it needs to be deleted and start over. Nobody wants to spend 5 days reading.
    If you don't like the question somebody ask - SKIP IT and say nothing. It's easier than taking time to send somebody to search.
    My pet peeve - Sorry.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
