MapPoint
Destinator
Streets & Trips
Other
My Fiero Build Thread
John, thank you for your replies. I'll check the Help file again but last night, I couldn't get to the screen where it shows volume for iGuidance and Winamp, and system volume. But then again, it was 2 in the morning, that could explain a lot
Thank you for your great skin.
I just installed digitalfx 2.22 but when I start roadrunner it says digital fx 2.0 on the splash screen. Is this normal or am I running old version? Is there somewhere that tells you what version of everything has loaded?
2.22 is the latest, and you are good with that. DFX 2.0 will remain the name of the skin, that is untill and if I get to 3.x.
John
Thank you for a great skin. I have one problem.
When I want go into the EQ setup, then RR minimize to the task bar.
Please help.
I have the same problem and in my case, once RR is minimized, I can't maximize it again. Have to kill it through Task Manager.
go here for info
Digital FX 2.0 Transparent Released
I have seen and tried several diff fixes for this issue as well and I believe that what I am currently using, is hands down "THE" fix for this, period! I found this on one of the users web sites from the forum ( W3bMa5t3r's I think), and really think that it should be mentioned somewhere, where it can easly be seen.
Link to file Plug-n-Play Blocker.exe
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
