MapPoint
Destinator
Streets & Trips
Other
Love the Skin, just have a couple of issues/questions.
First, I want to connect to the internet with my Blackberry. I did a small write up on the process here (http://www.mp3car.com/vbulletin/wire...ess-modem.html) and would like to modify one of the buttons of your skin to do this. Is there an easy way to add a button/modify the name of a button? What about just changing one of the current buttons to call the BB connector. Or better yet, adding the script to connect to the Net to the "reload" buttons on the weather/gas screens, and perhaps to the webplugin in screen.
Also, the "webplugin" screen doesn't appear to be working for me. I get a black screen that says "loading..." It seems to crash RR, though winamp continues, and RR is still in the windows task manager, the tile on the bottom of the screen disappears.
The last issue I am having is that, I have all my music in a folder called "music" (Imagine that) In that folder, I have folders for evey artist, and in the artists folders, I have album folders, and in the album folders, the MP3s (phew, that took a second to type), however, I can't seem to get the "music" folder into the Music browser. If I modify the rrconfig (the ini file) to a folder with mp3s, it works fine, but I can't get the top folder, "music" to load ALL the music. Is that a bug (it worked in my last skin) or do I have to change the way I have my music on the HD?
Thanks for the help,
Michael
look in the FAQ. you have to add a browse.rrl to your skin to be able to load all file i believe.
One more thing, is there anyway to "set" the GPS screen to keep the buttons along the top and bottom, instead of reverting to the buttons on the side each time the screen is changed?
Thanks,
Michael
My Fiero Build Thread
Ok, I have been using this skin for a couple of weeks now, and it's the best one I have used so far. The transparency thing is excellent. Excellent work!
So here are the things I can think of right now that I would change about the skin:
- Add version number to splash screen
- Fix the non-rotating 'E' on the compass in the GPS stats screen
- The speed dial in the GPS stats screen displays only in KPH, cannot get it to display MPH regardless of what the skin is set to in the settings menu
Looking forward to the next release!
1) I post the version number on the download site, as well as in the first post. It's just nor real practical at this time to change the Splash screeen graphic every time an update is made.
2) Sorry, I am not a flash programmer by any means, and the problem is in the swf itself. From the limited bit I know of flash is is a "Motion Tween" problem.
3) In RR config, Look for Imperial measurements, and change it there. I am using the Speedometer in MPH here, so I know it is a setting that needs to be changed.
Hello, first off this skin looks sweet, however, I can't get it to work for myself, I get a screen similar to this when I start it.
[IMG][IMG][/IMG][/IMG]
