View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #1801
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Arggggg, new problem, and this is wierd.
    Skin works perfectly, EXCEPT NOW, when I try and exit RR, the computer goes to 100 percent, and basically hangs. I can end it in task manager, and be fine, but anytime I exit it locks up. I have changed and tired other skins, and it will exit fine.
    The only thing I can think of is I just updated/redownloaded a program called Videora Ipod Converter. Not sure if that is causing the problem, I will try and uninstall and see what happens.
    Michael
  2. #1802
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    OK, small update, and I am sure this is really wierd and unique,
    All the other exit choices, shutdown, restart, hibernate, they all work. Only the actual EXIT choice causes 100 percent CPU usage.
    This only started recently. Worked fine all last week. Didn't really do much, except for the aforemention program download and install. I uninstalled it, and still the problem occurs.
    Wierd. I have a good working copy in the car, I might just copy and paste everything over, and see if that cures the problem.
    Michael
  3. #1803
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    This is definitely something I have never heard of before. The exit command is purely Road Runner, and no special code is executed when the DigitalFX skin is closed.
    My Fiero Build Thread
  4. #1804
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by JohnWPB View Post
    I know, it is WAY wierd. And it just started. But, it only happens with DFX, all other skins are fine. I thought it was a flash problem, but the skin works perfectly, except for the exit command. I tried your fixflash file, maybe I should uninstall and reinstall flash. Why I think it is a flash problem I am not sure. Just grasping at straws at this point.
    Have any idea how I can perhaps trouble shoot this, watch what is causing the problem, anything.
    Should I try a particualr roadrunner.exe? Have any suggestions/links to it.
    Thanks,
    Michael
  5. #1805
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It sounds like RR is trying to close an app and can't so hangs.
    have a look at the apps and scripts that are run in DFX.
  6. #1806
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Enforcer View Post
    Hmmmm, well, I am not starting anything other than WinAmp, and actually, that doesn't seem to be shutting down when I try to exit RR. Shutting winamp down manually, and then RR, doesn't help either.
    Once I attempt to exit, task manager shows that RR is using 90+% of the CPU resources. Even if I wait, it won't shut down.
    I don't have RR/DFX starting anything. Even if I just start RR, and then immediately exit RR, it still happens.
    I am stumped.
    Michael
  7. #1807
  8. #1808
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    could be some of the autoitx scripts or flash that DFX runs.
    Gonna uninstall and resinstall, see what happens.
    Yay
  9. #1809
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Well, I finally figured it out.
    SOMEHOW, the following lines were repeated in the exectbl.ini file,
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    Removed them, BOOM, it works fine now.
    Thanks everyone for the help, not sure how that happened, but at least I figured it out.
    Michael
  10. #1810
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    K, so, I know it is not your fault John, but does anyone else here notice a glaring problem with the sips.dat file,
    "90847","+33.786594","-118.298662","LONG BEACH","CA","LOS ANGELES","UNIQUE"
    "90848","+33.786594","-118.298662","LONG BEACH","CA","LOS ANGELES","UNIQUE"
    "90853","+33.786594","-118.298662","LONG BEACH","CA","LOS ANGELES","STANDARD"
    "90888","+33.786594","-118.298662","LONG BEACH","CA","LOS ANGELES","UNIQUE"
    "90899",,,"LONG BEACH","CA","LOS ANGELES","UNIQUE"
    "91001","+33.786594","-118.298662","ALTADENA","CA","LOS ANGELES","STANDARD"
    "91003","+33.786594","-118.298662","ALTADENA","CA","LOS ANGELES","STANDARD"
    "91006","+33.786594","-118.298662","ARCADIA","CA","LOS ANGELES","STANDARD"
    "91007","+33.786594","-118.298662","ARCADIA","CA","LOS ANGELES","STANDARD"
    "91009","+33.786594","-118.298662","DUARTE","CA","LOS ANGELES","STANDARD"
    "91010","+33.786594","-118.298662","DUARTE","CA","LOS ANGELES","STANDARD"
    "91011","+33.786594","-118.298662","LA CANADA FLINTRIDGE","CA","LOS ANGELES","STANDARD"
    "91012","+33.786594","-118.298662","LA CANADA FLINTRIDGE","CA","LOS ANGELES","STANDARD"
    "91016","+33.786594","-118.298662","MONROVIA","CA","LOS ANGELES","STANDARD"
    "91017","+33.786594","-118.298662","MONROVIA","CA","LOS ANGELES","STANDARD"
    "91020","+33.786594","-118.298662","MONTROSE","CA","LOS ANGELES","STANDARD"
    "91021","+33.786594","-118.298662","MONTROSE","CA","LOS ANGELES","STANDARD"
    "91023","+33.786594","-118.298662","MOUNT WILSON","CA","LOS ANGELES","STANDARD"
    "91024","+33.786594","-118.298662","SIERRA MADRE","CA","LOS ANGELES","STANDARD"
    "91025","+33.786594","-118.298662","SIERRA MADRE","CA","LOS ANGELES","STANDARD"
    "91030","+33.786594","-118.298662","SOUTH PASADENA","CA","LOS ANGELES","STANDARD"
    "91031","+33.786594","-118.298662","SOUTH PASADENA","CA","LOS ANGELES","STANDARD"
    "91040","+33.786594","-118.298662","SUNLAND","CA","LOS ANGELES","STANDARD"
    "91041","+33.786594","-118.298662","SUNLAND","CA","LOS ANGELES","STANDARD"
    "91042","+33.786594","-118.298662","TUJUNGA","CA","LOS ANGELES","STANDARD"
    "91043","+33.786594","-118.298662","TUJUNGA","CA","LOS ANGELES","STANDARD"
    "91046","+33.786594","-118.298662","VERDUGO CITY","CA","LOS ANGELES","PO BOX ONLY"
    "91050","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91051","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91066","+33.786594","-118.298662","ARCADIA","CA","LOS ANGELES","STANDARD"
    "91077","+33.786594","-118.298662","ARCADIA","CA","LOS ANGELES","STANDARD"
    "91101","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91102","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91103","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91104","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91105","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91106","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91107","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91108","+33.786594","-118.298662","SAN MARINO","CA","LOS ANGELES","STANDARD"
    "91109","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91110","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91114","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91115","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91116","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91117","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","STANDARD"
    "91118","+33.786594","-118.298662","SAN MARINO","CA","LOS ANGELES","STANDARD"
    "91121","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91123","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91124","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91125","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91126","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91129","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91131","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91175","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91182","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91184","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91185","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91186","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91187","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91188","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91189","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91191","+33.786594","-118.298662","PASADENA","CA","LOS ANGELES","UNIQUE"
    "91201","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91202","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91203","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91204","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91205","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91206","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91207","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91208","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91209","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91210","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91214","+33.786594","-118.298662","LA CRESCENTA","CA","LOS ANGELES","STANDARD"
    "91221","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91222","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91224","+33.786594","-118.298662","LA CRESCENTA","CA","LOS ANGELES","STANDARD"
    "91225","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91226","+33.786594","-118.298662","GLENDALE","CA","LOS ANGELES","STANDARD"
    "91301","+33.786594","-118.298662","AGOURA HILLS","CA","LOS ANGELES","STANDARD"
    "91302","+33.786594","-118.298662","CALABASAS","CA","LOS ANGELES","STANDARD"
    "91303","+33.786594","-118.298662","CANOGA PARK","CA","LOS ANGELES","STANDARD"
    "91304","+33.786594","-118.298662","CANOGA PARK","CA","LOS ANGELES","STANDARD"
    "91305","+33.786594","-118.298662","CANOGA PARK","CA","LOS ANGELES","STANDARD"
    "91306","+33.786594","-118.298662","WINNETKA","CA","LOS ANGELES","STANDARD"
    "91307","+33.786594","-118.298662","WEST HILLS","CA","LOS ANGELES","STANDARD"
    "91308","+33.786594","-118.298662","WEST HILLS","CA","LOS ANGELES","STANDARD"
    "91309","+33.786594","-118.298662","CANOGA PARK","CA","LOS ANGELES","STANDARD"
    "91310","+33.786594","-118.298662","CASTAIC","CA","LOS ANGELES","STANDARD"
    "91311","+33.786594","-118.298662","CHATSWORTH","CA","LOS ANGELES","STANDARD"
    "91312","+33.786594","-118.298662","CHATSWORTH","CA","LOS ANGELES","UNIQUE"
    "91313","+33.786594","-118.298662","CHATSWORTH","CA","LOS ANGELES","STANDARD"
    Picked 2 places and entered them into yahoo maps, and look
    http://maps.yahoo.com/#mvt=m&q2=Simi...4.204988&mag=8
    They are 50 miles apart, yet, they have the same Lat and Lon in the file.
    I wonder what can be done to improve that. Is SOCAL the only place that is affected by this? I am willing to donate to improve this.
    Michael
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
