View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #1901
    Mar 2007
    Nashua, NH
    New zips.dat file
    OK, I just finished modifying the 8+ MB file to add the leading '0'. I used Wordpad and just let it sit for ~30 minutes while I did something else. It managed to finish!
    Here's wiredwrx's file with the additional '0' on the 2nd coordinate. This is one big file (over 8MB when unzipped).
    Enjoy!
  2. #1902
    Nov 2006
    Issues with sound now
    I just upgraded to 2.0 transparent. I've been running the old one for MONTHS. New one kicks *** but i noticed that i had to use the roadrunner.exe that is included in this thread. Once i use that my volume settings are all messed up. When i go into RR the volume changes to 100% and I cant adjust the volume up or down unless i first hit MUTE then UNMUTE. and when i change the volume its at weird percentages...I am use to 1-10% going up in increments of 1% then 10-100 in 5% increaments.
    I've noticed the new Roadrunner.exe in this thread is about 2.4mb but the most current roadrunner.exe issued from the creator is much much smaller. Whats the difference?
    Never had any issues before I upgraded. THe new skin works great just sound issues.
  3. #1903
    Mar 2007
    Nashua, NH
    Quote Originally Posted by meisner View Post
    Enjoy!
    Damn...it was just pointed out to me that there are still some errors in the file I posted. I searched and replaced all occurances of ","-with ","-0
    This works fine for the entries that had only 2 digits for the longitude. I didn't notice that some entries already had 3 digits. Mike is updating the database again.
    Sorry for the bad version guys. But it is a step closer.
  4. #1904
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    So here it is, new and improved, and completely correct (I HOPE)
    Also, it turns out that when the file is in the correct format, it works even if using the entire 8meg file.
    Enjoy.
    Michael
    Attached Files Attached Files
  5. #1905
    Jun 2002
    Virginia
    I also modified the 8 meg file with all the correct digits and did a thirty minute drive through a couple of small towns to confirm that it all works. I did notice that sometimes it doesn't change when it's supposed to. For example, I drove through one small town called Midland and it didn't change from the previous town. Then when I drove back through Midland in the other direction, it did change to Midland. I don't know what that's all about.
    Wiredwrx and Meisner, I also discovered that we needed to leave the coordinates with three digits alone. I'm assuming that the file posted above and mine are now identical, so I won't bother to post mine.
    Anyway, I have verified that the large size of the file will not keep it from working, at least on faster computers. It does appear that the new file is more accurate than the one we've all been using, so Wiredwrx should be commended for his hard work in putting the new one together. Wiredwrx, I believe other skins may be using this functionality as well, so you may want to make the updated available elsewhere. Perhaps you should post a new thread with a link to the download.
  6. #1906
    Mar 2007
    Nashua, NH
    Correct me if I am wrong here, but I believe the way this works is the dat file has coordinates that designate the center of a circle. The dat file dictates the details of the city this circle encompasses. So there will be some errors here and there since cities are not round.
    Also, you may have seen a problem due to the update interval (localdatacaptureinterval=1). If this is set higher (or you made it thru Midland in < 1 minute), you may have missed that update.
  7. #1907
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Wow, this Database seems a difficult and uncooperative one to get right
    Florida still does not work, as well as Georgia, parts of Virginia, West Virginia, North Carolina, South Carolina, Alabama, Mississippi, Kentucky, Iowa, Tennessee, Michigan, Ohio, Indiana & possibly some other states.
    Looking at the zips.dat, the the above mentioned states, the line looks like the following:
    "33401","+26.712300","-080.062300","WEST PALM BEACH[hl],,FL[/hl]","PALM BEACH[HL],,[/HL]STANDARD"
    The highlighted area above is the problem. Looks like the search and replace did not work correctly with these states, and turned out putting double coma's.
    My Fiero Build Thread
  8. #1908
    Jun 2002
    Virginia
    That's my understanding as well.
    That makes sense.
  9. #1909
    Jun 2002
    Virginia
    Quote Originally Posted by JohnWPB View Post
    Florida still does not work, as well as Tennessee, Michigan, Ohio, Indiana & possibly some other states.
    The error is in the original file posted by Wiredwrx; it was not a search and replace error. I don't think double commas appear anywhere else, so a search and replace should take care of it.
  10. #1910
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    There were 72,380 replaced using [hl],,[/hl] as the search string and [hl],"[/hl] as the replacement.
    Also found some strange errors in these lines, that can prob just be removed to keep the info accurate, and not freak out the scripts in Road Runner:
    "57578","+0.000000","0.000000","WEWELA","SD","TRIP P","STANDARD"
    "57778","+0.000000","0.000000","ROCHFORD","SD","PE NNINGTON","STANDARD"
    "07423","+41.000000","-074.100600","HO HO KUS","NJ","BERGEN","STANDARD"
    "10301","+0.000000","0.000000","STATEN ISLAND","NY","RICHMOND","STANDARD"
    "10303","+0.000000","0.000000","STATEN ISLAND","NY","RICHMOND","STANDARD"
    "10310","+0.000000","0.000000","STATEN ISLAND","NY","RICHMOND","STANDARD"
    "11219","+0.000000","0.000000","BROOKLYN","NY","KI NGS","STANDARD"
    "12739","+0.000000","0.000000","GODEFFROY","NY","O RANGE","STANDARD"
    "14846","+42.548500","-078.000000","HUNT","NY","LIVINGSTON","STANDARD"
    Well, there's a lot of em with 0.0000 so I can't post em all here, seems to be about 85 lines or so with blank information....
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
