MapPoint
Destinator
Streets & Trips
Other
You need the bigger version of RR.exe to use all the latest and greatest features contained in DigitalFX. I'm not aware of anyone else having the volume problems you're having.
OK, can someone download this version and verify it. I wrote a C program to go through the DB and clean it up. I *BELIEVE* it looks right now but want someone else to verify it.
I am also copying it to my carpc and will use it durign the drive home.
Steve
Hey all,
I think I may have asked this before but I can't find the thread or the answer. When using this skin and going to DVD, the DVD doesn't keep where it was. In other words, it keeps restarting every time you leave the DVD screen. the other functions all work. GPS works great, music ok, and regular divx is good. But the DVD won't continue. any suggestions?
I have a question about using Streets and Trips 2007. I would like the view button to work to get to the night view. It only switches between topo and regular view. Is there any way I can change this?
I already tried this and tried again and still no luck.uote: Originally Posted by YellowMater View Post
I still have an eq button causing RR to minimize. I checked my rr mixer file and the correct line is there "mixer_off.jpg,mixer_off.jpg,mixer_on.jpg,Mixe r_do wn.jpg"
Do I need to change something else? This is the mixer file in rr under skins, digital, mixer?
Try this :
http://www.mp3car.com/vbulletin/1088049-post1582.html
I am changing the mixer file in program files/rr/skins/digitalfx/mixer? Is that correct? Is there a place to go to check to see if I need jpg or png? Do I need to change the rr configuration file?
\skins\DigitalFX 2.0\mixer.skin the file that needs to be changed . In that same folder should be the mixer_off and mixer_on files (mine are png). Attached are mixer.skin, mixer_off.png, and mixer_on.png that I have if that helps. AFAIK, the problem is just that the mixer.skin is pointing at images that don't exist...in my case pointing at jpg's when I had png's. Still doesn't work???? I'd reinstall the whole skin and make sure you have the required RR version installed.
CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
MediaLaunch for RR
Online Check for RR
Locker for RR
I love this skin! And it sort of foced iGuidance on me due to the poll!
I am having several problems and I have searched this enormous thread and could not find the right combination of phrases that would help.
1. Cant figure out how to make the GPS Speed gauges look the way they do in the screenshots. this is what I get:
2. I use a bluetooth GPS mouse, for some reason the GPS compass and even speed and satillites work on the main screen, but when I goto GPS and open the iGuidance program it can not find the GPS even after the settings are verified. However, if I close out of Road Runner and then open iGuidance (Same directory and filename) its finds the GPS mouse fine and works great.
Could it be a problem with the main page tryign to connect to the GPS mouse at the same time as the program causing a conflict?
3. cant seem to get the transperancies working correctly. Perhaps I dont have the proper requirements? DirectX ? Active X? What does it require to work correctly? And perhaps its realated to the GPS speed gauge underlay?
Thanks all for anyyou can give!
Centrafuse 3.1
Garmin Mobile PC
GPS, OBDII, Lilliput 629GL, Nightvision integrated video,
Other fun stuff in works.
