Thats the same I get.
MapPoint
Destinator
Streets & Trips
Other
Now that you mention it, I am also unable to get the installer to work for BM.
Script: D:\RoadRunner\Run\Skins\Digital FX BM\InstallDigitalFxBlue1.vbs
Line: 190
Char: 44
Error: File not Found
Source: Microsoft VBS runtime error.
I downloaded again today and still get the same error.
I downloaded red and bm, checking them all out. I don't use the installer because of other settings that I have.
It takes a while to check everything out, can't imagine how long it takes to do these changes......ugg
Will post back
Thanks tons as always
Tennessee Vols Fan
JohnWPB,
I was wondering if you plan on releasing a "transparent" version? One that people could put their own background image -- like to did here....
http://www.mp3car.com/vbulletin/show...&postcount=710 (turtle)
and here:
http://www.mp3car.com/vbulletin/show...&postcount=823
Nasa
I installed a new PC, so I used the installer today. Worked fine. I only did not know where to extract the files, so I extracted them into the OE RR folder. (No, I didn't read the directions).
So, does the installer include everything??? RR, skin, winamp etc?
Also, with my new PC, my XM is on COM1. When I launch XM I only see my music files listed, instead of XM stations. I tried switching to COM 2, it then shows the XM stations, but still only plays my music. I'm certain my XM is on COM1. help?
Winamp would only play on my LF speaker. (windows media played on all 4) so I downloaded the latest WinAmp which works fine (on all 4 speakers)
Only other issue is that when I first start RR, I hit either volume button and the volume drops. <confused>
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
So far so good, the only issue I'm seeing is on the SAT info button. Speedo needle floats around.
mr civic search this thread or the blue devil thread on vbscript error. there is a file/installer from microsoft that you need to download and install. I had the same problem but can't find the post that linked the page to microsoft.com
John, can we integrate a port splitter like xport3 into the skin? that way if there is some kind of problem with the gps not turning on we can solve the problem through the skin.
Cars:
2001 Lexus es300 carpc Complete!Lexus es300 thread
CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
2006 Lexus es330 next project.
Noticed something minor in the Copper Skin. The button layout on the music player screen is different to the others. Copper still has the separate repeat/shuffle buttons, so it does not have the "Rate Song" button that the others colors have.
Also another minor one. In the original Blue Skin you renamed the "Search" button on the playlist screen to "Super Search". In all the other colors the button is still labeled "Search". Also the "Super Search" skin is still blue in all the other color versions. How's that for nitpicking.
For some reason even though the Jump to File "Super Search" loads up in the Red, Copper and BM Skins it only actually works in the Blue Skin. I've looked at the files and I can't figure out why. If I run Blue it works great but it never shows any files with the other colors. The Jump to File Search is really sweet, thanks for adding that!
*Edit- Figured out the "Super Search" problem above. Has something to do with the way the plugin loads. If I click on the "Cancel" button within the search window and close the plugin and then hit the "Home" button to go back to the previous screen, the Search Screen loads fine the next time.
