View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2041
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    Help
    Not sure what i did but all of a sudden my audio is always in ramdom within the album. double checked buttons with editor, checked settings in rrconfig and they are all set to not shuffle. Anyone have any ideas.
  2. #2042
    Feb 2007
    Richmond Virginia
    For those of you using Street & Trips 2007 and having problems with the old skin file you might want to use this instead.
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    StreetsTrips_OFF.png,StreetsTrips_OFF.png,StreetsT rips_ON.png,StreetsTrips_OFF.png
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,491,0,103,70,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%Ri",
    /, A, x, y, w, h, color R;RGB, G, B
    A01,-1,71,802,450,"Microsoft Streets & Trips",0,0
    B01,195,0,100,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TV","Guidance Pane"
    B02,97,0,98,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TN","Find Near"
    B03,294,0,99,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%UR","Route Planner"
    B04,693,0,105,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;{F3}","ReRoute"
    B05,2,521,104,77,"EXIT","EXIT"
    B06,205,521,95,77,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZO","Zoom Out"
    B07,300,521,102,77,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZI","Zoom In"
    B08,394,0,97,71,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%TGS||SENDKEY;%TGM||SENDKEY;%TGA||A CTIVATE;- Microsoft Streets & Trips||SENDKEY;%VL"," Activate GPS"
    B09,106,521,100,77,"EXITMENU",
    B10,695,521,103,77,"MASTERMUTE",
    B11,595,521,100,77,"VOL+",
    B12,500,521,94,77,"VOL-",
    B13,401,521,98,77,"PLAY",@STOP||PLAY@
    B14,0,-1,96,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^m","MAP STYLE"
    B15,592,0,101,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TGS||ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TGM||ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TGA","TRACK"
    /, Y, Back Slider file path
    Y01,"vslider1\slider_*.gif"
    Y02,"vslider2\slider_*.gif"
    Y03,"slider_battery\slider_*.gif"
    Y04,"slider_signal2\slider_*.gif"
    END
    This will fix the view button to work. Also if you press the gps button it automatically opens full view, auto rotate etc. The directions button still does not work. I am a noob in this but the main things I was interested in fixing are now working.
  3. #2043
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Yellowmatter: Thanks! I added your changes to the master skin here, and will be in the next release.
    My Fiero Build Thread
  4. #2044
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    Media Copy Problem
    Hey all,
    First, I've had the skin up and running for about a week now, and it's working WONDERFULLY.
    I've read in a few posts back the EQ problem, I'll update the skin soon to fix that.
    The one problem I can't seem to resolve though, is that the Media Copy utility doesn't seem to want to read my DVD drive.
    I'm able to successfully copy files from it in Windows Explorer, but when I select drive "D:\" in the Media Copy utility, nothing happens. The DVDRom doesn't spin up, and the screen remains blank.
    I posted about this in a separate thread, but the conversation died pretty quickly, hoping I can get more action here. :-)
    Digital FX2.0 Transparent Media Copy problem
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
  5. #2045
    Jun 2002
    Virginia
    Has anybody else had trouble with the traffic plugin over the last week or so? It has been working great for me up until then and now I get a continuous loop saying "Traffic Data is not currently available. Please try again in a few minutes." Same thing on both my car and desktop.
    I know this isn't a skin issue, but since the plugin is included with DFX, I figured a lot of DFX users are using the plugin.
  6. #2046
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I am not sure what the media problem is with reading the CD. I have tested that here, as well as thumb drives ect. It really is just a front end for windows explorer, and should, by all intense purposes, show whatever windows itself would show. I will look into seeing if I can figure out something, but just don't know where to start looking really....
    Unfortunately the traffic map had to be pulled from the skin It was something I used quite frequently myself. The site that the plugin uses to gather/scrape the information was completely re-designed. This broke the plugin, and I do not know if the author of it will take the time to fix it or not. If along the way the plugin is repaired, I will definitely add it back into the skin. But for now, pressing the Traffic button will bring up the Traffic Camera plugin from Enforcer. You will have to download and install that yourself, as he has asked that it not be included with the skin. He wants to make sure that people get it from his site, and that it is the latest and most updated version.
  7. #2047
    Jun 2002
    Virginia
    Quote Originally Posted by JohnWPB View Post
    That's what I figgered, but no mention of it was made on the plugin thread. That was a really handy thing to have. Hopefully, Moahdib will resurrect it.
  8. #2048
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You will need to add an extra indicator/button to your trafficam skin for the version I will be releasing in a couple of days.
    Code:
    I,x,y,w,h,"MAP",""
    Found one use for the GPS coords.
  9. #2049
    Jun 2002
    Virginia
    Quote Originally Posted by Enforcer View Post
    We've got some of the best brains on this forum (e.g. Sonic, W3bMa5t3r) living in the DC suburbs. Hopefully, we can figure out a way to get camera data for Northern VA and Maryland around the DC area.
  10. #2050
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by kbreeden View Post
    forgive me for bein late to the party again but doesnt enforcers plugin have the cameras in our area? If not i'll see if i can give him the source to my traffic cam plugin (if i already havent.. i've gotta crappy memory.)
    Live mp3Car Facebook Chat
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
