Originally Posted by
YellowMater
For those of you using Street & Trips 2007 and having problems with the old skin file you might want to use this instead.
MEDIACAR Skin
MEDIACAR MainMenu Skin
StreetsTrips_OFF.png,StreetsTrips_OFF.png,StreetsT rips_ON.png,StreetsTrips_OFF.png
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B,491,0,103,70,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%Ri",
/, A, x, y, w, h, color R;RGB, G, B
A01,-1,71,802,450,"Microsoft Streets & Trips",0,0
B01,195,0,100,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TV","Guidance Pane"
B02,97,0,98,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TN","Find Near"
B03,294,0,99,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%UR","Route Planner"
B04,693,0,105,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;{F3}","ReRoute"
B05,2,521,104,77,"EXIT","EXIT"
B06,205,521,95,77,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZO","Zoom Out"
B07,300,521,102,77,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZI","Zoom In"
B08,394,0,97,71,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%TGS||SENDKEY;%TGM||SENDKEY;%TGA||A CTIVATE;- Microsoft Streets & Trips||SENDKEY;%VL"," Activate GPS"
B09,106,521,100,77,"EXITMENU",
B10,695,521,103,77,"MASTERMUTE",
B11,595,521,100,77,"VOL+",
B12,500,521,94,77,"VOL-",
B13,401,521,98,77,"PLAY",@STOP||PLAY@
B14,0,-1,96,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^m","MAP STYLE"
B15,592,0,101,71,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TGS||ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TGM||ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%TGA","TRACK"
/, Y, Back Slider file path
Y01,"vslider1\slider_*.gif"
Y02,"vslider2\slider_*.gif"
Y03,"slider_battery\slider_*.gif"
Y04,"slider_signal2\slider_*.gif"
END
This will fix the view button to work. Also if you press the gps button it automatically opens full view, auto rotate etc. The directions button still does not work. I am a noob in this but the main things I was interested in fixing are now working.
