View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2241
    Constant Bitrate DeadlyAP1's Avatar
    Aug 2005
    MA
    chgrec,
    I use the transflective screen in my s2000 and it works great even with the top down. No matter what is on the screen, I can see it clearly. If you are having issues with the sun, that may be the way to go for you.
  2. #2242
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    spectrum analyzer not embedding
    Hey all,
    I'm having problems trying to get the spectrum analyzer visu working correctly. When I click on visualization under both music and the hot spot on the main page it just brings winamp and the visu to the front (it doesn't embed either in album art or on the top). the transparency doesn't seem to be working either. I followed john's steps in the help file and I'm running winamp ver. 5.13, I also added a screensavers.ini in the root of RR with these lines
    AvsTransparent=true
    FadeOnIdle=false
    SecondsToFade=300
    FadeInterval=10
    DefaultOpacity=40
    MaxOpacity=200
    I am using bluezx3's config, and have avs selected, I also tried "other" with !Winamp Gen!AVS for the window name, still no luck, tried unchecking avs transparent also.
    here's my music section of rr.ini
    [Music]
    musicpath=C:\music\
    playlistpath=Click here to set path
    useid3=3
    showid3playlist=true
    showid3browse=true
    lazytag=true
    singleclickaudio=false
    noformat=false
    listnumbers=true
    listfollowssong=true
    resumemusic=0
    audiorepeat=false
    audioshuffle=false
    id3listformat=%title%
    id3browseformat=%title%
    titlesafter=-
    albumart=*.txt
    fadeimages=true
    audiofiles=.mp3,.wav
    visuname=!Winamp Gen!AVS
    scrollmode=1
    circularlist=false
    groupnumbers=false
    picspath=C:\Program Files\Road Runner\skins\DigitalFX 2.0\Backgrounds
    Any help and suggestions would be awesone.
    I should of never watched john's new video , before that I didn't know what I was missing.
  3. #2243
    Jan 2007
    Im pretty sure this probably isnt a skin problem, but this thread feels like home...lol. The only skin ive ever used is Digitalfx. Im having a problem with mpc again. When playing a video it plays fine. However when i touch the screen the controls dont scroll up like they used to, but I can touch where the buttons usually are when they are visible and they still work. So its kind of like the buttons are invisible but i still have functionality. Anybody know whats wrong? Thanks in advance.
  4. #2244
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i had this
    Quote Originally Posted by MrCummings View Post
    and guino told me it might be the mediainfo.dll in the rr folder have a look if its there and delete it.
  5. #2245
    Aug 2006
    Loving 2.5 But for some reason when i try use Mappoint Europe 2006 and click GPS in road runner it loads Mappoint but doesn't Integrate it into Road runner it just opens it on its own in a new window So confused please help
    many thanks Rob
  6. #2246
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by rob_69er View Post
    many thanks Rob
    The quickest and easiest way to fix it, is to open the menu.skin file in a text editor.
    Find this line:
    B06,559,261,240,83,"RememberGPS",@gaspricefinder@
    And replace it with this one:
    B06,559,261,240,83,"LOAD;Mappoint_GPS.skin;Mappoin t;C:\Program Files\Microsoft Mappoint\Mappoint.exe;Mappoint",@gaspricefinder@
    You should also do this to each of the menu.skin files in the menus subfolder in the DigitalFX skin directory. If you don't, and you change the menu layout through the skin, it will overwrite your changes.
    My Fiero Build Thread
  7. #2247
    Dec 2006
    BROOKLYN NY
    everytime i hit change skin color ditigal fx freez any1 havin that same problem
  8. #2248
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I believe that you need to check the picspath in the rr.ini file, make sure you either added it or changed it to the backrounds folder in the D FX skin folder.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #2249
    Sep 2007
    the dogs danglies!!!!!! thanks for your time and effort
    wish we had all of the features over here in the uk that you guys got in the us
  10. #2250
    May 2007
    Bothell, WA
    i know that you probably think that i did not do what was told for me to do when installing your skin by adding the lines from the 'add rr' file. well, i did. i added the lines, and even the optional ones. now i can change my skins manually by going to the notepad file and editing it there by changing the path everytime i want to change the skinface, but it just doesnt seem to work from your skin. i dont know what i did wrong. i even reinstalled your skin to see if i can refix what i may have did wrong, but came with the same results. somehow, for the skinface listings, its redirecting it to my image viewer folder. i have been trying to find out which file i can edit the path, but i cant seem to find it. any help? thanks in advance!
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
