View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 23 of 376 FirstFirst ... 13141516171819202122232425262728293031323373123 ... LastLast
Results 221 to 230 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #221
    Nov 2005
    John,
    I could not get the installer to work for the BM skin. I get a file not found error. The installer worked fine for the original Blue Devil skin, and even the Beta Digital FX Blue skin. Is there something I am missing?
  2. #222
    Jun 2002
    Virginia
    Quote Originally Posted by Zeeshan0581 View Post
    Thanks for the answer kbreeden, since ur not John.
    I wasnt asking him if its possible to do so...
    Yeah, nothing like a newb coming in and wasting John's time by asking for a custom setup and then showing a bunch of attitude when someone nicely explains that it can't be done. Hey Newb, John's working on a bunch of stuff that will benefit the forum as a whole and can't be wasting time on custom setups for people. Of course, maybe you could send him a large donation and then ask again.
  3. #223
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by jmciver View Post
    John,
    It is just me, nothing you are doing wrong I am trying to keep track of all the different skins, images, installers and stuff is slipping through the cracks. I changed everything in the installer to use dynamic path's so HOPEFULLY that will fix it.
    My Fiero Build Thread
  4. #224
    Oct 2006
    CT
    John,
    I had the same problem, but after installing the Blue skin, I copied the BM skin folder to RR/skin/ folder, and BM works.
  5. #225
    Oct 2006
    CT
    Quote Originally Posted by kbreeden View Post
    Attitude? i think it was you showing attitude to start off with.
    You still dont know what i was asking him, which he explain in the post.
  6. #226
    Oct 2006
    CT
    Quote Originally Posted by JohnWPB View Post
    Ok, then who were you asking?, now I am confused
    For each menu change, it involves changing the the PSD files, and then saving them out in on,off,down for each of the 2 menu's and doing that again for the Digital Clock menu variation, as well as for the new digital clock / compass Variation in the next release. That makes a total of 18 images to create just for a simple menu rearrangement. I wish I could do it, but there is just no way....
    I was asking you about it. That is exactly what i was asking for. I guess i will have to wait till you post the PSD files.
    Thanks for the response
  7. #227
    May 2006
    BM Installer Error Message
    John, ref your #224: here is error message I get with the 01/16/07 4:16 am download:
    Script: E:\RoadRunner\Run\Skins\DigitalFX BM\Install DigitalFX BM|.vbs
    Line: 205
    Char: 10
    Error: File not found
    Code: 800A0035
    Source: Microsoft VBScript runtime error
    [I am not certain what the character is after the BM in the file name, above]
  8. #228
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    JohnWPB,
    Managing so many different variants of your beautiful work seems like it would be very time consuming.
    May I inquire why you don't create a folder, defined by an environment variable, where the *default/general* files are located and only have the seperate PSD files in thier individual folders? That way only PSD files have to be managed when installing a new theme.
    I am at work right now, so I can't see what files can/can't be seperate out. But I figured it might be something to look at....
    Nasa
  9. #229
    May 2006
    BM Installer Offending Lines
    Commenting out the following three lines allowed the installer to run to completion (NoteTab Pro line numbers):
    Line 220: objFSO.CopyFile "Road Runner\Mp3Art.dll" ,RRPath, OverWriteFiles
    Line 228: objFSO.CopyFile "Road Runner\ScreenLock.dll" ,RRPath, OverWriteFiles
    Line 229: objFSO.CopyFile "Road Runner\screensaver.ini" ,RRPath, OverWriteFiles
    RRPath = E:\RoadRunner\Run\
  10. #230
    Nov 2005
    Quote Originally Posted by ron1 View Post
    Line: 205
    Char: 10
    Code: 800A0035
    Yup, that is the error I was getting. I was going to install it manually but I wanted to make sure you knew about the installer issue. I will give your fix a try and see what happens.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
