Page 2 of General
MapPoint
Destinator
Streets & Trips
Other
okay..this is what i have for my settings:
how do i enable the debug option?
Page 2 of General
Hi I just installed the skin, But iguidance4 doesn't seem to work from DFX. If I press GPS I get to the iguidance screen but the middle is black, If I press on the arrow on top right I get the iguidance menu. But when I press on anybotton like destination or gas nothing happens and all other buttons stop working and I can't get out of that menu.
Also if I go to RRconfig and I press the save button, and restart RR it will load with the native skin instead of DFX.
TIA
Any ideas as to how I can change the text color? Trying to change it to blue to match my interior at night. Am I going to have to edit in photoshop? Ok. I found how to change the font color. Now How do I change the text color on the buttons?
try changing the "External DVD Program Name " option.
from the " WinDVD " to "Intervideo WinDVD 6"
on the first picture of the windvd. it is not in-bedded in RR. looks like WinDVD has change there window name.
run the winDVD. Look at the taskbar and see what the program calls it's self. in the option I stated above type it as you see it on the task bar , in that option .
I just tried it here and it is working fine, can you define "Corupts the rr.ini"?
I am using iG4 myself, and it is working correctly here on my desktop, and in the car. Make sure you have iGuidance set up correctly with the correct path, and window name iGuidance.
As for saving the ini, that sounds like a problem with the new config editor. I would post that in the new config editor sticky thread.
The buttons are graphics, you can load them into a graphics editor like photoshop, and use the paintbucket/fill tool to change the color.
When the next DFX is released, you can just change the font color in the menu/menu2.skin to change the font colors on the main menu screens.
My Fiero Build Thread
I Know That You Have A Plugin To Play A Cd Or Dvd When Is Inserted In The Any Drive. Is This Going To Be Part Of The New Release. I'm About To Put My First System Together.
