MapPoint
Destinator
Streets & Trips
Other
Yes, that will be built into the skin. It's prettty neat to pop in a CD, it starts playing, eject it, and it goes back to what was playing, and where it was in the song all automatically.
My Fiero Build Thread
When i mean corrupt i mean RR can't read it. RR.ini can't be open. This happen twice to me already. I am unable to delete the file. Only way to delete is to use WINPE or ERD Commander. IF not I have to change the whole Road Runner directory. It happen everytime i try to use autoswitch. Didn't happen before. Just happen when i use the new RR from 9/2 i believe.
Hmmm something strange is going on for sure, I just do not know what..... If this was a bug with the skin, I think it would have been brought up a long time ago. The code for the Auto Switch has not changed since around January or so.
What has changed with the new RR release was the new config utility. So.... I am not sure of it is due to the fact that it writes the ini in a standard format now. Section/Key/Value. RR only writes Key/Value and does not put it in a certain section.
I have tried like 4 times changing all the values on the auto switch screen, in many combinations, and closing RR and restarting it without issue. I know you are having a problem, and do not doubt that for a second, I just cant find or reproduce it.
Will this work if I connect anything with music (Flash drive). Next Release?
okay..i just tried that..do i have to put "platinum" after that as well since mines platinum? it didnt say "platinum" in the task bar. also, when i do watch the dvd after rr minimizes, then i remaximize rr, when i click the arrow back button to the main menu, the dvd stops playing and windvd closes. once i press the dvd button again to watch the dvd, i have to also reopen windvd so i can play my dvds. any help on either? or both? thanks for all your efforts!
John, how close are we to the new release? I am driving down to VA (8hr drive) for a huge car meet in a couple weeks and look forward to the new version for the ride and to show off![]()
