Ok, I really want to get this installer working for everyone. I just spent a couplf of hours going through the installer script and adding a bunch of code. It appears that the problem, was not really a file not found, but had to do with overwriting a file that was registered, and possibly in use. The scrip will no longer copy the .DLL's if they exist already, but will still register them just to make sure. It will also no longer change your screen resolution you have set in the general.ini file, as well as not overwriting your pin code for the screen lock utility.
Someone please give this Brushed Metal version a try and let me know. If all is will I will fix the other 3 installers, and re-upload the complete packages to the server.
EDIT: You will get a few pop-up's that I forgot in the installer script, saying either copied or not copied, those were for testing purposes, and will be removed when released officially on the site for download.
DigitalFX BM.zip
LinkBack URL
About LinkBacks
