MapPoint
Destinator
Streets & Trips
Other
well anyone have any ideas??
Tisk, Tisk
OT, I have also been running the famous Tiny rev5 for..can't rember, and have absolutey one HUGE problem.....IT JUST WORKS!![]()
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Yea, This is a RR issue, and not the skin (for once!I noticed that myself a couple days ago. I posted a note about it in the bugs thread. The last RR version that it worked on was 9/30/07. Guino changed a couple things on the visu's, so it also prob broke the commands to switch the visualizations. If he is unable to get it working again, do to his changes, I have a script that I wrote that can talk to Winamp directly to make it work again. Lets just see if RR is fixed, before I go that route.....
My Fiero Build Thread
Question
1. I've installed Super search, and noticed the Jump to File DFX skin in the root of RR; how does that embed to the DFX skin. I've read the help file, but it doesn't explain how to embed it. I'd like to replace the "search" button with the Super Search. The "Library Search" works great too, but find the realtime filter of the Jump to file more convenient.
2. How to you set WinAmp to automatically start playing when RR is started and start where the song left off (pause). I have to manually press play everytime I start RR and starts from the beginning. Nevermind I figured it out. Uncheck Mute RR upon Exit
LOW IMPORTANCE John **REQUEST**
1. For us Laptop users, is there any chance you can put a battery meter icon or remaining % next the GPS icon in the main music window in the top left?
2. Is there anyway to move the "Play Album" to the first Music menu? Possibly replacing the "Player" button. This way it avoids having to Click Music >> Browser >> Library Search >> Play Album There's countless times when I hear a song from an album and would like to play the entire album.
Thanks Either way!
This is a winamp version problem. Make sure you are using Winamp 5.13. I have had the exact same problem, and tried many WInamp versions before settling with 5.13
1) I ran out of places to put buttons, and thus replaced the "super search" with the library search. I will tinker around and see if I can add a way to put that back in again.
2) Yea, I should be able to do that, and actually most likely will, as I am in the process of switching out my CarPC for a laptop as well. The idea is to have it standby when I turn the key off, and have instant on when starting the car. With some testing, I have estimated that the Laptop will remain in standby for around a week. If the battery drops to 10%, I have it then set to just go into hibernation.
3) Hmmmm I will see what I can come up with to try to make it more easily accessible. Possibly as a button choice for one of the 16 menu buttons, or on the rate song skin. The rate song is accessible by tapping the name of the song on the top of the main menu screens. I will prob add that to all the skins where the song title is shown.
On another note, I have gotten a little side trackedI finally have my Touchscreen installed in the wall! (Yes, that is Road Runner in the last picture controlling the lights and such
i'm trying to change the images for the weather skins but i can only get the temp.jpg to show. i changed the weather .ini file for the url's and changed the ext. where needed, but i still keep getting the usa maps come up, also is there a way i can change the default on the interactive map.
these are the url's i'm useing
interactive map:http://www.weather.com/outlook/trave...opnav_business
sat map anime:http://image.weather.com/looper/arch...?1192531791187
sat map non-anime:http://www.metoffice.gov.uk/weather/...0710161000.jpg
radar non-anime:http://www.metoffice.gov.uk/lib/template/spacer.gif
Could you implent an option so that you can choose to change the weather options to european maps and weather?
