View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2731
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    rrconfig problem denk
    open rr folder open launch folder opend rrconfig folder, then open the rrconfig.ini
    and change the window name its different to the origanal config,and check the path is going to where rrconfig is,this is whats being called a t the moment.
    as for the video try dselecting the video again sometimes it dose not load 1st time.
    same with the pic viewer its just 1 of those things
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #2732
    Aug 2007
    Thanks carputer1, i'll try that tonight
  3. #2733
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    I gave up on trying to get WinDVD to work, so I got PowerDVD, which embeds fine into the skin. But, the play and Title menu dont work, and when I click on the root menu, it start playing the DVD. Do the buttons have to be changed for it to work with PowerDVD? Also, how can I lose the powerDVD menu bar at the top? Thanks.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  4. #2734
    Sep 2007
    I couldn't get WinDVD working neither.. I have version 8.0 anyone got it working? PontiacGA, how's powerDVD working for you?
  5. #2735
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    how bout using powerdvd as an external app - although the buttons are really small...
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  6. #2736
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    dvd
    windvd dose really not like to work properly ,so you are going on the right track with powerdvd, i use ver.6 as it embeds nicely. you do have to change the button codes for it to totally work. download simplistic skin it has a powerdvd skin in it, just copy the codes over. as for the name windvd in the skin ,that is embeded in the skin, can not be changed. but if you wait till the next release that john will put out shortly, you will be able to change the name to what ever you like. correct me if i'm wrong John.
  7. #2737
    Mar 2006
    Pennsylvania
    Quote Originally Posted by sonvan View Post
    Works great once I get the buttons right.
    Carputer: Thanks. I'll give it a try.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  8. #2738
    Constant Bitrate digeratix's Avatar
    Sep 2007
    How do I integrate rrmobile into this? Phoco is not working right and I wanted to try RRmobile, but do not know how to install it. Its barking at me about a skin.
  9. #2739
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Powerdvd Buttons code
    Quote Originally Posted by PontiacGA View Post
    Hey man, could you put the buttons code for Powerdvd that you take in this thread?
    Regards
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  10. #2740
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    all you have to do pontiac
    is attach the skin file to your post, not the graphics , just the file. if thats not pos. i'll post 1 tonight.
    EDIT: heres the skin file for dfx powerdvd, just take the .txt out of the name and drop it into your skin file. i have just made this up blindly ( no skin editor on this comp) so any problems let me know
    Attached Files Attached Files
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
