View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2751
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    IMO, RadioShark blows. it works fine if it is in a wide open area and stationary. Once you have to put it in your trunk and you're driving, the radio cuts in and out all the time. i've been looking for a decent hack, but have yet to find one that actually boosted the performance enough to be constantly usable. the only good thing i can say is that it easily migrates and works with RR
  2. #2752
    Nov 2006
    How to get the 5 star rating/playlist to function?
    Hi all, I am using this skin and loving it, however I cant seem to make the 5 star rating system on the songs work. When I rate a song, it seems to take but when I go in under the 5 star listing in the skin, there are no songs listed. Is there something I need to toggle on?
    Also I tried searching but this forum is so huge and it was bringing up stuff completely different from this skin.
    MantisX
  3. #2753
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by MantisX View Post
    MantisX
    1st off did you make a playlist folder in your music directory.
    if you did ,in the playlist screen go to load playlist and see if its there, if so just select it and load.
    also if your loading from the playlist load screen it will only say 1star,2star and so on it dose not list as tracks,it will only list as tracks in the playlist screen when loaded.
    you could also load from the ratings screen but you already know that.
    may not be the answer but 1st thing 1st
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #2754
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Quote Originally Posted by the_crooked_toe View Post
    Maybe that's the problem: putting in the trunk. I would consider putting it behind the rear seats on the console exposed to the sky (like my GPS). Have you tried it this way?
    Anyhoot, i better get some feedback from others on this RadioShark. I was ready to go out and buy it...
    Let's see what john has to say about HD and what hardware requirements, as well as it's integration into DFX.....
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  5. #2755
    Dec 2006
    Quote Originally Posted by afterdigital View Post
    Have you connected the radio Shark to the antenna on your truck. I bought a right angle connector which is about 6" long with a Female connector and one and and a male connector at the other, cut of the male connector and replced it with the same type that comes on the little external arial. Seems to work quite well when driving.
    BTW - Remember you must get the RadioShark 1 - Radioshark 2 doed not work with RR.
    Cheers
  6. #2756
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    HD Radio
    How's HD radio different from Analog radio? Are you talking hardware? Will there be an additional button on DFX? Will you remove the old Radio button?
    Just curious cause currently i don't use the radio but i'm planning on doing so soon. I would like to know if i should bother buying a USB radio tuner such as RadioShark - or just wait until this HD radio is alive and kicking and get different hardware as needed...
    HD radio differs in the actual audio quality of the audio. It is a digital signal, -vs- an analog signal. I have yet to hear it myself, but have read multiple times the audio quality is a night and day difference.
    Yes, it is a hardware device, around $130 or so from what I have seen. The great part is it supports the HD AM & FM, as well as standard AM/FM. It has built in support in RR.
    As far as the skins go, with the new dynamic buttons on the menu's you will be able to choose "Radio" or "HD Radio" depending what you are using on your system.
    You can check THIS THREAD for the model numbers and search google for the hardware, as well as a list of stations avail in your area on page 2 or so in that thread. In my area I have over 30 stations broadcasting in HD.
    Oh, one more note, any station can have multiple "sidebands" or station choices. For instance one station here that broadcasts on standard FM here, is a classic rock station. They also have avail a HD version of the same broadcast, as well as a 2nd HD feed that is the same station, but caters more to hard rock. Basically, this one station in my area, has 3 feeds to choose from.
    On another note, I have not been posting as much as normal in this thread, as I am really trying to get all of the stuff ready for the next release. That, as well as being a Moderator now, has increased my PM's to about 5-10 a day, as well as about 5 or so emails a day pertaining to Road Runner and the skin. I am glad to see a lot of you helping to answer some of the questions in the thread, thank you all very much.
    My Fiero Build Thread
  7. #2757
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Gatso
    Hi John.. eagerly waiting for the dynamic skin that u r working on....
    and since ur in this process of redoing every thing....
    can u add a function for GATSO hunter as well instead of we running it in a separate window....( the funtions to add cam and edit ) will make things a lot more comfortable and classy
    thanx
    vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  8. #2758
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    gatso
    Quote Originally Posted by vicky_obee View Post
    thanx
    vicky
    you don't have to have gatso hunter,as you can add speed cams to d6 via favourites , but you will need a convertor program , will look into that for you as i want to do that to, but if you still want gatso i have a different skin i use for d6 which has gatso labels at the top, and you can have gatso in your start up folder which will also start gatso and rr.
  9. #2759
    Dec 2003
    Hey thanks for the cam alert function in D6.... well if it can be done in favourite then it cool. was trying to add in but could not figure out as how do i add CAM in Favourites....
    pls advice
    thankx
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  10. #2760
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    vicky
    as this is off topic in this thread. so i'll post findings in the thread Using D6 that you started.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
