View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2761
    Constant Bitrate digeratix's Avatar
    Sep 2007
    Possible the wrong area for this....
    Using phoco with RR and DFX2(skin) I can use RR to make calls just fine, cant read the phones contacts and such, but I can make calls.
    MY problem right now is while on RR main page listening to music, I get a call on my cell, I get no notifcation on screen. Cant accept a call.
    Why is that?
    Also how do I make it to where I can see my contacts on my nokia 6682?
  2. #2762
    Sep 2007
    Ah solved it myself, BALLOON TIPS in XP MUST be ENABLED.
    As for the phonebook, synced with outlook express and saved as csv file, then used the pbconverter.
  3. #2763
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    I have this skin and Iguidance 4.0.. in the gps option of the screen how do i get the county, zip and city to display the county, zip and city??
  4. #2764
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Do you have the GPS ant. hooked up? I *THINK* it gets it directly from the GPS. Try clicking on the area where it says city and such.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  5. #2765
    May 2003
    Florida
    Quote Originally Posted by PontiacGA View Post
    Oh ya computer is been in my car for month and a half and yes gps ant is been hooked up.
  6. #2766
    Jun 2002
    Virginia
    Quote Originally Posted by kickercivic1 View Post
    Make sure you have the latest version of Road Runner. Also make sure your rr.ini contains the following:
    localdatacaptureinterval=1
  7. #2767
    Dec 2006
    Atlanta, GA
    ok, i tried changing the background and got the greyed-out problem . . . and i did add the lines to the rr.ini as the installer told me to. what gives?
  8. #2768
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    Quote Originally Posted by kyds3k View Post
    try to add those lines again some times it wont work the first time you added those line
    same thing happened to me i've tried 3 times and it work
  9. #2769
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    backgrounds
    look in your rrconfig(new ver. by blue) in there you will find picspath direct that to your backgrounds folder in the skin file, all so check the background path in rrconfig.
    this sounds wired but you have to havethe same path in both .
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #2770
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by Zogg View Post
    Great skin, John!
    I've been away for a while but came back just in time to try out the new version. Got most things working, but one thing that isn't is the Image Viewer. When it starts I see:
    <- BACK
    < VIEW IMAGES >
    instead of it just going to a picture. No problem, I pick VIEW IMAGES and the first image in my folder shows up. But then none of the buttons work. I can use the keyboard and it responds, but no joy with the onscreen buttons. Any idea why?
    Thanks, Z
    ok guys i'm bringing this back from the dead because it was never answered in any of my replies. these are relating to posts 2139-2141. ImageViewer works outside of road runner by using the keyboard, and it also works fine when inside of road runner using the keyboard. But the buttons in DFX will lock up ImageViewer. anyone else seeing this result?
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
