View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2771
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    imageviewer
    Quote Originally Posted by the_crooked_toe View Post
    ok guys i'm bringing this back from the dead because it was never answered in any of my replies. these are relating to posts 2139-2141. ImageViewer works outside of road runner by using the keyboard, and it also works fine when inside of road runner using the keyboard. But the buttons in DFX will lock up ImageViewer. anyone else seeing this result?
    ok just tryed this out for ya.freash install of xp and rr,dfx2.5, i do this time to time on test bench.
    i have no trouble at all with it all buttons work as should,
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #2772
    Constant Bitrate digeratix's Avatar
    Sep 2007
    I have noticed while using Phoco with RR/dfx2.0(skin) that in a call, I cant press any digits like on a menu based call.
    For instance if I call my local time temp plus and it tells you to press 1 for movie times, you cant.
    Is there a work around for this or will this be implemented into your skin in the future?
    Zorro (phoco maker) says "This feature is supported by PhoCo but not implemented in all skins."
  3. #2773
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by carputer1 View Post
    all of my pictures are over 1mb. do you think that has anything to do with it?
    what does your code look like on ImageViewer.skin?
    EDIT**
    tried it with pics lower than 250kb. almost the same result. the buttons work but you have to click them repeatedly to get the pics to change. and it's not consistent.
  4. #2774
    Dec 2006
    Atlanta, GA
    Quote Originally Posted by erricson_nguyen View Post
    try to add those lines again some times it wont work the first time you added those line
    same thing happened to me i've tried 3 times and it work
    those lines are each in my rr.ini, but not all together in one place. still getting grey
    do i need to downgrade my flash or something?
  5. #2775
    Sep 2007
    Anyone have any idea as to why my usb gps which is on com port 10, works with iguidance, but not with RR on the DFX2 skin at the same time.
    At first it works with RR and I can see the gps stats and all, then no dice in iguidance, I check the port and its wrong, so I set it, then iguidance works, but there are no longer any stats in RR.
    What is this behavior all about?
  6. #2776
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Quote Originally Posted by kbreeden View Post
    Make sure you have the latest version of Road Runner. Also make sure your rr.ini contains the following:
    localdatacaptureinterval=1
    That did it. Thank you.
  7. #2777
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by digeratix View Post
    If i understand your problem, you have to split that port (10) into 2; one for RR and one for IG. Xport3 is the program you need. Search for terms like "split gps"; "xport3" "comm port splitter" and such and you will find instructions..
  8. #2778
    Sep 2007
    Is trafficam included with this DFX skin? I don't see it
  9. #2779
    Raw Wave
    Jun 2002
    Virginia
    Yes, you definitely need Xport. In the Helper Files subfolder in the DigitalFX skin, you will see Xport3.zip. Unzip that and read the instructions and you should be on your way.
  10. #2780
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    image viewaer and backgrounds
    crooked: yep your getting there some of my pics i have to hit the button a couple of times to move on, as for the skin file i made changes from the origanal DL.
    kyds: have you tryed to reload the skin or rr, sometimes things don't reg 1st time, try reging the gdipluswrapper.dll. see if that works. and just to be sure open rrconfig and check that on page 2 under general you have gdi+ in the fastmode box and the background path goes to where you have the backgrounds folder.
    sovan: trafficcams is not included with the skin you have to download it from enforcers thread.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
