View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2781
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    when the config is opened, it does reg the gdipluswrapper.dll...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #2782
    Dec 2006
    Atlanta, GA
    Quote Originally Posted by carputer1 View Post
    kyds: have you tryed to reload the skin or rr, sometimes things don't reg 1st time, try reging the gdipluswrapper.dll. see if that works. and just to be sure open rrconfig and check that on page 2 under general you have gdi+ in the fastmode box and the background path goes to where you have the backgrounds folder.
    check, check . . . still getting grey! could it be because it's on Vista (i plan on using XP when i'm actually running the carputer, this is just for testing till i fix the laptop i plan on using)?
  3. #2783
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    theres your problem
    Quote Originally Posted by kyds3k View Post
    there has been talk about issues useing vista, all i know about that is run as adminastrator and in xp compatipal mode, best search the forum for vista and rr if you intend to continue with vista as a test bench some people have had some success. have a look here.
    http://www.mp3car.com/vbulletin/road...a-32-64-a.html
    http://www.mp3car.com/vbulletin/road...os-use-rr.html
    these might help you out
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #2784
    Low Bitrate esko's Avatar
    Jun 2007
    Quote Originally Posted by digeratix View Post
    Anyone have any idea as to why my usb gps which is on com port 10, works with iguidance, but not with RR on the DFX2 skin at the same time.
    At first it works with RR and I can see the gps stats and all, then no dice in iguidance, I check the port and its wrong, so I set it, then iguidance works, but there are no longer any stats in RR.
    What is this behavior all about?
    I guidance doesn't work well with ports higher than 9. The best thing to do is use xport and set it it something like this. GPS = comp4, iGuidance 9, DFX 10.
    Good Luck
  5. #2785
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi every 1
    can u pls help me out...
    I am using Detinator maps... on the GPS / map screens... i see there is a possibility for the COUNTRY/ city name to be displayed automatically ( guess from lat/long )
    but i am not able to display this.... is it a function og Iguaidance or will it work with destinator aswell.....
    pls let me know
    thanx
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  6. #2786
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    city etc.
    Quote Originally Posted by vicky_obee View Post
    Hi every 1
    pls let me know
    thanx
    i if i'm right in what you are after, this will not work for you due to the zips.dat file is for the US only at the moment.
  7. #2787
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    crooked: yep your getting there some of my pics i have to hit the button a couple of times to move on, as for the skin file i made changes from the origanal DL.
    so the program still isn't 100% functional if you have to continually hit the button for it to work. i will have to drastically reduce the size of all my images then for it to be able to browse
  8. #2788
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sorry for the delay
    Quote Originally Posted by the_crooked_toe View Post
    i have been looking at this, i have set a few pic's at different sizes and so on,
    all my pics'show up , with different effects to imageviewer, ie. slows down,double press buttons,slide show on some occassions did'nt run,
    most of my pics are are about 25 -35 k in size and in different res's
    so yes there is problems there. but as this is an exterenal plugin and not what john made,its not something that is going to be sorted out i don't think.
  9. #2789
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not in this thread anyway...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #2790
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    true
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
