View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2791
    May 2007
    I'm having DVD issues and maybe it's just my understanding of how it's supposed to work. I started off by using WinDVD and it didn't integrate well with RR/DFX so I switched to PowerDVD and quite honestly, that's not integrating well either. I've made the skin changes to load the "windvd" skin but basically what is happening is I'll get the movie to run and the on-screen controls appear for a bit, then disappear and there's no way to get them back or end the movie without a right click to close the player. Then it takes several tens of seconds to get the controls back. For whatever reason it's like PowerDVD/WinDVD is going fullscreen and I guess there's no way to control that?
    I also used MPC and had similar results. I've verified the window names are correct, etc.
    Any advice?
  2. #2792
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    check out post #2327 and on - it discusses windvd setup
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  3. #2793
    May 2007
    Quote Originally Posted by afterdigital View Post
    Seems like the same problems I've had but with no resolution. I'll have to mess around with it some more when I get home but I'm sure I've tried everything thus far.
  4. #2794
    Aug 2006
    Des Moines, Iowa
    Could someone please help? I am running the latest version of RR and DFX and it's is working well but I have a problem that I just can't figure out. I have read many posts and did a lot of searching before I decided to post. When I run GPS Stats it works fine but I am not getting the city state info at the top. I have tried several different zips.dat files with no luck. Also I have the latest dll from Meisner. When I go to the gas price finder screen the car pc locks up and RR is not responding. Most of the time I can't even put in my zip code manually before it locks up and even if I do nothing comes up. When I was running a older version of RR and DFX it did work. I have reloaded several times and just can't figure it out. If my GPS stats is working and my zips.dat and dll is ok what else should I try? Thanks in advance.
  5. #2795
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by swj123 View Post
    Make sure you have the latest version of Road Runner. Also make sure your rr.ini contains the following:
    localdatacaptureinterval=1
  6. #2796
    Jul 2006
    Delete ziplocator.DLL
  7. #2797
    Aug 2006
    Des Moines, Iowa
    Deleting the ziplocator.dll worked. Thanks! I must have searched and read posts till my eyes were sore the last two days. I guess I don't understand why it was in the install if it caused problems. Anyway RR and DFX are working great in my Lexus RX300. Thanks for the help. Mike
  8. #2798
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I'm redoing my carPC, new HDD, new case, and some other stuff.
    Reloaded everything: latest RR, latest DFX, Winamp5.13, Flash, etc.
    When I start RR I get "Failed to load control "Flash" from. See image.
    RR then quits and my taskbar is gone. If I where to minimize this I'd have rewrite this post again. If I minimize something it's gone, and I have to restart it.
    Any ideas please?
    EDIT: Woah...sorry about the image size.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  9. #2799
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    try installing adobe flash player?
  10. #2800
    Nov 2006
    I'm not sure if this been brought up before but whenever playing music under "Playlist" and change the volume (add) RR minimizes to toolbar but music still playing.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
