View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2801
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by slvrsol View Post
    try installing adobe flash player?
    Yes, done.
    Thanks, but don't worry about it...I'm installing and messing with WinLite anyway.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  2. #2802
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this was
    Quote Originally Posted by zyr55 View Post
    I'm not sure if this been brought up before but whenever playing music under "Playlist" and change the volume (add) RR minimizes to toolbar but music still playing.
    when some changes were made on last release, go back through the thread , your looking for the ser pack john did, DFX serv.1 this should fix your problem
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #2803
    Sep 2007
    how can i make music stop?
    it only pauses with the button of Dfx
  4. #2804
    Constant Bitrate digeratix's Avatar
    Sep 2007
    Is there any particular reason we should be using winamp 5.13?
    I currently am using winamp 5.33 pro and love its cdripping capabilities.
    Could it be incorporated into the cd rip instead of the current cdrip.exe thats being used? Winamp seems to be faster.
    Also I know this is almost a very ridiculous question, but in winamp, how do I make it no randomize the visualizations? I like the spectrum analyzers and once I get there finally after tons of touchtaps, it randomizes into something else. I want it to stick, and be able to easily find what Iwant.
  5. #2805
    Sep 2007
    Quote Originally Posted by dhmv2001 View Post
    I love this question as I would like to stop music at times too. Centrafuse has an options similar where you can do this in the library.
    I want DFX to be able to do this also.
  6. #2806
    Oct 2007
    Help Microsoft Streets & Streets
    Hi! I need help. I followed instructions found in this thread to setup S&S but couldn't make it work. I am using S&S 2006, Could anyone of the genius in here kindly show me step by step how to make it work with this wondering skin. Right now whenever I press GPS button, S&S loaded up on it own. What are the step to take to have S&S work like the one on this picture, I got this from this link http://www.mp3car.com/vbulletin/rr-s...ml#post1057525, Sorry for my bad English
    Thanks everyone for helping
    Anchim
  7. #2807
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    to make it stop
    hold the play / pause button
  8. #2808
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    visiual
    Quote Originally Posted by digeratix View Post
    open winamp outside rr, go to the oreference for the vis. at the bottom you'll see a box tcked with 10 sec's random detick that, i don't think was a real reason in 5.13 apart from the vis's
  9. #2809
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    setup is in the help file
    Quote Originally Posted by anchim View Post
    Anchim
    open the skin exectbl file in there about 3/4 of the way down you will seethis line :
    /Streets & Trips
    /Uncomment the following line by removing the forward slash to make Streets & Tips the GPS Default program
    /"GPS","LOAD;StreetsTrips.skin||RUN;C:\Program Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips" take the comment line out / and set up rrconfig. path to s&t , window name Microsoft Streets & Trips
  10. #2810
    Mar 2006
    Sweden
    still problem with volume up button
    Hello, this will be my first post here although I have been up and running with my car-pc for 2 years now.
    I have been using the same old skin and rr-release during this time, but now dropped in here to the forums and saw how much had happened with RR and skins while I was gone.
    I just love this skin and its features.
    Now to my problem: When I use the library search feature under music tab, then try to increase volume in this window, RR minimizes and I cant bring it up again.(MapMonkey does not minimize)
    Have to use ctrl/alt/del to be able to close RR.
    This is a problem because i dont have a keyboard in my car and have to do a hard reboot.
    I have read about others with same/similar problems and they have been recommended to install "Service pack 1" wich I have done, but still no change.
    I have spent some time time searching this thread (Its getting pretty big), so please dont tell me to use search-function.
    Maybe I have just missunderstood something, or missed something obvious.
    Please help me solve this.
    Apologies if my spelling is bad, Im from Sweden.
    Thanks in advance...
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
