View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2811
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this will sort the libary search skin out
    Quote Originally Posted by Devon View Post
    Hello, this will be my first post here although I have been up and running with my car-pc for 2 years now.
    I have been using the same old skin and rr-release during this time, but now dropped in here to the forums and saw how much had happened with RR and skins while I was gone.
    I just love this skin and its features.
    Now to my problem: When I use the library search feature under music tab, then try to increase volume in this window, RR minimizes and I cant bring it up again.(MapMonkey does not minimize)
    Have to use ctrl/alt/del to be able to close RR.
    This is a problem because i dont have a keyboard in my car and have to do a hard reboot.
    I have read about others with same/similar problems and they have been recommended to install "Service pack 1" wich I have done, but still no change.
    I have spent some time time searching this thread (Its getting pretty big), so please dont tell me to use search-function.
    Maybe I have just missunderstood something, or missed something obvious.
    Please help me solve this.
    Apologies if my spelling is bad, Im from Sweden.
    Thanks in advance...
    the button codes are all wrong,just DL the attachment take the .txt away from the name and drop into the skin folder
    Attached Files Attached Files
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #2812
    Constant Bitrate digeratix's Avatar
    Sep 2007
    Quote Originally Posted by carputer1 View Post
    open winamp outside rr, go to the oreference for the vis. at the bottom you'll see a box tcked with 10 sec's random detick that, i don't think was a real reason in 5.13 apart from the vis's
    Please be more specific or something I am not seeing that.
    This is what I see.
    [media]http://thebatchfile.homeip.net:8080/junk/pictures/1.jpg[/media]
    [media]http://thebatchfile.homeip.net:8080/junk/pictures/2.jpg[/media]
  3. #2813
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    close follow the confirgue vis bit
    your looking for this screen right hand side at bottom 10 seconds
  4. #2814
    Sep 2007
    Thank U.
    To clarify for anyone that is having the trouble in finding this as I did, its open winamp, start a visualization, right click on the visual, select AVS editor, then click on settings, and Presets/Hotkeys
  5. #2815
    Mar 2006
    Sweden
    Thanks, that did the trick.
  6. #2816
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    no mmatter what i do
    added the folowwing line in DFX Exectbl
    "GPS","LOAD;StreetsTrips.skin||RUN;C:\Program Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
    and gps window name and PATH in rr config also S&t
    ms S&T skin wont load it just loading IG skin instead
    what did i do wrong? need help
    thanks in advance
  7. #2817
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    did you set
    Quote Originally Posted by erricson_nguyen View Post
    thanks in advance
    in config ,external gps, and is the path code correct, also try this line:
    "GPS","LOAD;StreetsTrips.skin"
  8. #2818
    Oct 2007
    Thanks for the helps. So far I got S&S to shown up in RR, but still came with wrong skin. Don't know this is right, I added this line "GPS","LOAD;StreetsTrips.skin" to DF Exectbl.ini
    /Streets & Trips
    /Uncomment the following line by removing the forward slash to make Streets & Tips the GPS Default program
    This is how the skin look, what do I do to get the right skin to load?
    Thanks for helping.
    Anchim
  9. #2819
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    sorry my fault
    did'nt explain right. comment the line in exectbl.ini again as before.
    the line i posted in last post put that in your menu skin
    so comment this line again
    and put this line in the menu skin
  10. #2820
    Mar 2007
    Nashua, NH
    In the DFX 2.5 help file, under Installation, it is mentioned the iGScripts folder must be copied to the rr root folder. Is this still true with the later versions? I ask because I never noticed this before and have never done it.
    from the help file:
    "Copy the IGScripts folder to the root of the Road Runner folder.
    EA: c:\program files\Road Runner\iGScripts"
    ...or is this only for manunal installation? I did the automated install, but I don't have an iGScripts folder under rr.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
