View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2821
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    igscripts
    Quote Originally Posted by meisner View Post
    In the DFX 2.5 help file, under Installation, it is mentioned the iGScripts folder must be copied to the rr root folder. Is this still true with the later versions? I ask because I never noticed this before and have never done it.
    from the help file:
    "Copy the IGScripts folder to the root of the Road Runner folder.
    EA: c:\program files\Road Runner\iGScripts"
    ...or is this only for manunal installation? I did the automated install, but I don't have an iGScripts folder under rr.
    from what i can tell from the skin files it stays in your skin folder
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #2822
    Apr 2007
    new install file?
    i've been having problems trying to install the skin. i tried to d/l it on two separate computers, my desktop and carputer, without any anti virus installed. still it keeps giving me an "error 11FD", even on different computers.
    anyone has a working install file, which has no installation problems? i'd really appreciate it. if it works for me, i'd love to donate to the skin creator!
  3. #2823
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by carputer1 View Post
    i have been looking at this, i have set a few pic's at different sizes and so on,
    all my pics'show up , with different effects to imageviewer, ie. slows down,double press buttons,slide show on some occassions did'nt run,
    most of my pics are are about 25 -35 k in size and in different res's
    so yes there is problems there. but as this is an exterenal plugin and not what john made,its not something that is going to be sorted out i don't think.
    sorry to keep bringing this up. If you are within the skin and you use the keyboard (pressing n or p) the pictures change with no hiccups, delays, or multiple touches. When you use the skin's next or previous button, then you start getting errors. so really it seems like there is an error either with the skin controls, or the program is buggy.
  4. #2824
    Oct 2007
    did'nt explain right. comment the line in exectbl.ini again as before.
    the line i posted in last post put that in your menu skin
    so comment this line again
    "GPS","LOAD;StreetsTrips.skin||RUN;C:\Program Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
    and put this line in the menu skin
    "GPS","LOAD;StreetsTrips.skin"
    Thanks for the help.
    I followed the step. still not work. here what I did and the files I have changed.
    1-select exectbl.ini located in skin folder of DF
    2-remove the forward slash from this line
    Before remove forward slash
    /Streets & Trips
    /Uncomment the following line by removing the forward slash to make Streets & Tips the GPS Default program
    /"GPS","LOAD;StreetsTrips.skin||RUN;C:\Program Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
    After remove forward slash
    /Streets & Trips
    3-Located the file Menu.skin within DF folder and I paste this line "GPS","LOAD;StreetsTrips.skin"
    in there before the word END.
    please let me know what else I did wrong or need to be change.
    Thansk for the help
    Anchim
  5. #2825
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    the only thing
    Quote Originally Posted by the_crooked_toe View Post
    i can come up with at the moment is the sendkey commands are a bit slow to responed, i'll have a play again when i finish work.
  6. #2826
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok i'll
    Quote Originally Posted by anchim View Post
    /Streets & Trips
    /Streets & Trips
    Thansk for the help
    Anchim
    , can you post you rr.ini ,exectble.ini and your menu skin file so i can make sure thats right,
  7. #2827
    Oct 2007
    Thanks for taking your time to help me.
  8. #2828
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    right make the changes
    RR.ini
    gpspath=C:\Program Files\Microsoft Streets & Trips\Streets.exe
    gpsname=Map - Microsoft Streets & Trips
    ExecTBL.ini from DF folder
    / DigitalFX Skin Custom Commands
    /Streets & Trips
    Menu.skin
    B06,559,261,240,83,"GPS"Change
    "GPS","LOAD;StreetsTrips.skin"Remove
    do me a favor edit your last post and delete the files you posted , just makes it 1 hell of a post cheers mate
  9. #2829
    Oct 2007
    RR.ini
    /Streets & Trips
    Menu.skin
    Okay, I got it to work follow your instruction, but I accidentally closed the S&S app and now only S&S skin shown up, not S&S. If I manually open S&S then it ok. What's next?
    Sorry to bother you so much. your help is very appreciated.
    Anchim
  10. #2830
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i take it
    Anchim
    after you closed S&T you went back to main menu and pressd the gps button again, to see if it restarted it.
    on another tip for S&T spoon feeding time have a look here this may give you some ideas http://www.mp3car.com/vbulletin/road...2006-skin.html
    Streets 07 GPS enable via skin command?
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
