View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2831
    Oct 2007
    Quote Originally Posted by carputer1 View Post
    after you closed S&T you went back to main menu and pressd the gps button again, to see if it restarted it.
    on another tip for S&T spoon feeding time have a look here this may give you some ideas http://www.mp3car.com/vbulletin/road...2006-skin.html
    Streets 07 GPS enable via skin command?
    Okay, I got it to work now. for some reason the path in ExecTBL.ini was changed.
    The Directions button doesn't seem to work. when press, the drawing menu came up.
    Thanks hanging along with me. very appreciated.
    Anchim
  2. #2832
    Aug 2006
    Des Moines, Iowa
    Hello, is there a reason that the spectrum analyzer wont work with the later versions of Winamp?
    This is from the DFX help file.
    "You will need to download and install Winamp 5.13. Winamp versions between 5.13 and 5.32 WILL NOT WORK!"
    Just curious. thanks
  3. #2833
    Constant Bitrate digeratix's Avatar
    Sep 2007
    What I really woudl like to see, is how to make winamp pro be the tool used for ripping cd's since is soo fast at it.
  4. #2834
    Nov 2007
    Everything but the radio...
    like it says pretty much everything that i need to work is working, The radio is a Dlink DSB-R100 Using it with Radiator, and it does work with the scan and direct tune and such but either the presets aren't working or I just don't know how to set them
    To set presets do you just enter in the station freq. and hit enter? When I do and the preset shows up instead of showing ie: 1: 104.1 it will show 1: 0-104.1
    Thanks for any help
  5. #2835
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    have you tryed
    Quote Originally Posted by ds21 View Post
    Thanks for any help
    this in another skin.someone elses skin, as i don't use this myself,if you can try it with say bmv2 skin rr default skin see if it works, if it dose then its a matter of changeing the codes to the buttons
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  6. #2836
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    just to let people know
    i under estimated how busy this trhead can be.
    i'm getting on average 5 pm's and about the same in e-mails a day at the moment.
    so if i have not answered you yet ,please do not think i have ignored you, i just don't have the answer yet,
    also getting questions that can be found through the search utitlity, can you please try every avenue before asking the question, this is not a dig,
    it just helps, most of my evenings are now tired up with this along with other projects i'm looking into ,and i have a wife that a kiss and a cuddle dose not cut it anymore.
    so bear with me i'll get there.
    cheers
  7. #2837
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Streets & Trips Directions problem
    open the streetstrips skin file, and change the very first button you come to ,its set alone from the rest of the button code.
    change it to :
    B,491,0,103,70,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%ui",
  8. #2838
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Holy Crap! Christmas came early for me this year! It looks like there will, be with 100% certainty, HD Radio support for the skin DaveDog was extremely kind enough to send me a brand new DMHD1000 unit! Thank you , Thank You, Thank You!
    As an update, the skin is coming along slowly but surely..... There are a lot of new features and additions for sure... But thats being kept under wraps for now For starters, lets just say, that for those with Internet connections in the car, you will be able to search for just about any song on the planet the same way you search for a local song, and be able to play it almost instantly More details will be revealed later, but it is fully integrated into Road Runner, and works with the standard skins and iLists
    I have been working on the skin 4-5 hours a day and will continue to do so until it is completed.
    Thanks again to those helping to answer questions here in the thread, it helps me a lot stick to working more on the skin.
    My Fiero Build Thread
  9. #2839
    Oct 2007
    John,
    How do I bribe you to integrate slingplayer for slingbox in to your awesome skin?
  10. #2840
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by dmistry View Post
    John,
    Send him a SlingBox!
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
