View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #2851
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by carputer1 View Post
    is it the rateings database by any chance,
    That is only the very very tip of the Iceburg!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #2852
  3. #2853
    Jan 2006
    Philadelphia
    1)open your rr folder, then the launch folder,then rrconfig folder,in there you'll see the rrconfig.ini, change the window name and path to the new rrconfig
    2)if you hang on a bit longer ,john is changing the skin,so you can change the buttons to what you like,the .png's will be blank off text ,the text will all be done as labels,makeing it easy to change,and hes makeing it pos.to select the button codes via amenu skin.listing the different buttons you can use plus blank 1's for your own add on's
    1)The config just isnt working. I got the filedir correct, but maybe the name is off. I tried RoadRunner Config (as per the properties of the shortcut), I tried RR Config-Blue ZX3 (as when it opens and what it displays on the top), and I tried RRConfig. No luck
    2)The new update sounds fantastic! I will wait for that one.
    With your music player: Is there any better way to view all music? I accomplished it by putting all the music into a playlist, but then browsing the music is difficult. There is no quick way to move around in the playlist, other than holding down the double arrow.
    I like the A-Z buttons in the Browse command. Is there any way to turn the Player Album Art (the big screen on the left side in 'Player') to a list? Browser feature is nice but doesn't list songs alphabetically and includes folders. It lists the folders alphabetically, but when you have songs in the main folder, they have a random order. This random order may be caused from bad ID3 tags in my music, I will look into this.
    To try to better explain this; I would like to be list all the songs (no folders) alphabetically in one list with the browsing features of Browser (A-Z and thumb wheel (which is awesome btw)).
  4. #2854
    Aug 2006
    Des Moines, Iowa
    Two questions please
    1 What do I have to do to get the rr config to open in DigitalFX?
    2 What is the best plugin or program to get album cover art?
    The DFX help file pointed to
    http://louhi.kempele.fi/%7Eskyostil/projects/albumart/
    which does not work.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Album Art in Road Runner
    Quote Originally Posted by swj123 View Post
    I forgot to fix the link in the help file, but I did update the link some time ago in the FAQ section at the top of the RR forums. Check the "How do I display album art, and where do I get it" FAQ.
    My Fiero Build Thread
  6. #2856
    Constant Bitrate digeratix's Avatar
    Sep 2007
    I use this to get my covers.
    http://www.softpedia.com/get/Multime...wnloader.shtml
    Thank goodness for amazon.com
  7. #2857
    Aug 2006
    Des Moines, Iowa
    Thanks for the info on the album covers. I appreciate it. I have RR and DFX working well but just working out a few small problems.
    One last thing, When in DFX I used to be able to go into rr config but for some reason I can't any longer. I have to use the rr config on the desktop. No biggie but is there a doc somewhere on that?
  8. #2858
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    replace the settings.skin in your DFX folder with this one(minus the .txt part)
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #2859
    Aug 2006
    Des Moines, Iowa
    Tried that but rr config still didn't open in DigitalFX. Mike
  10. #2860
    Jul 2006
    I'm sure you've already though of this... but is the config you have named RRConfig.exe or RR Config.exe?
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
