View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #3161
    Low Bitrate VettePC's Avatar
    Dec 2007
    iguidance 3
    Anyone have this issue? Iguidance 3 reverts back to COM1 everytime I close and re-open the program.. well, sometimes it doesnt loose it. What causes this? Using RR & DigitalFX 2.5 skin. Have Xport running to split to COM 16 & 17. GPS receiver is on COM3. Set RR GPS to COM 17 (GPS STATS works every time i open it in DigitalFX. If I run Iguidance standalone and select port 16 it runs fine. Then close it and start RR and usually it will work. After closing RR and re-open Iguidance alone or through RR it is reverted back to COM1!
    What causes this!?
  2. #3162
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    is a well know issue in iG not skin or RR problem, you must use a com port lower than 9 if you use 10 or higher will reset to 1.
  3. #3163
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by brandensin View Post
    Is there a way to list the songs in alphabetical order in browsing an album?
    Very Very soon...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #3164
    Dec 2007
    Thanks El Camino... yes, that fixed the problem! I know that this has been posted before , but I also have found that much of the info on here is hard to find, and I never know how old of a post will provide the correct solution for current issues. I did spend several hours searching and reading, so I wasnt asking for a "spoon feed"
    Thanks again
  5. #3165
    Dec 2007
    Latest issue is RR freezes after about 1 minute no matter what I do. I just re-installed everything 2 days ago. Carefully trying to get this all working. So far just Installed latest binary files and latest DigitalFX installer. Set pics path, Winamp 5.13 path. Added a few albums to winamp. Installed Xport... Set input from my GPS to COM3 --> Enabled COM6 & COM7 for Iguidance 3 and GPS in RR. All seems to work, then FREEZE. Winamp continues to play but RR must end task along with Winamp.
    Not sure where to go from here...
    Here's my rr.ini in case that helps:
    [General]
    winamppath=C:\Program Files\Winamp\
    hidewinamp=true
    launchpath=Click here to set path
    startcommand=
    voice=false
    disableinternat=false
    exitmute=true
    showicons=false
    showextensions=false
    hidemouse=false
    hidetaskbar=false
    hidedesktop=false
    hidedots=false
    gpstime=false
    gpsusadate=false
    exitmode=0
    dateformat=Short Date
    timeformat=Short Time
    locale=0
    screentype=4:3
    debugmode=false
    enableclipping=true
    nozoom=false
    usegestures=false
    leavemousealone=false
    closeapps=false
    fastmode=-1
    usedualmon=false
    soundcard=0
    screenlimit=10
    mastervolmap=0
    hibernateaware=true
    forcehibernate=false
    hibernatereload=true
    usbsound=false
    browsertype=0
    usevoicecontrol=false
    usecar2pc=false
    fadeinvolume=true
    [Skins]
    skinpath=C:\Program Files\Road Runner\Skins\DigitalFX 2.0\
    transition=-1
    backgroundpath=To set path,Click --->
    [Gamma]
    gammamode=3
    gpsgammamodeoffset=0
    gammaday=0:0:0
    gammanight=-50:-50:-50
    gammadaytime=1:00
    gammanighttime=1:00
    autogammamode=1
    autoskinmode=1
    [Preload Screens]
    preload=
    [Music]
    musicpath=Click here to set path
    playlistpath=Click here to set path
    useid3=0
    singleclickaudio=false
    noformat=false
    listnumbers=true
    listfollowssong=true
    resumemusic=0
    audiorepeat=false
    audioshuffle=false
    id3listformat=%title%
    id3browseformat=%title%
    titlesafter=-
    albumart=*.txt
    fadeimages=false
    audiofiles=
    visuname=MilkDrop
    scrollmode=1
    circularlist=false
    groupnumbers=false
    picspath=C:\Program Files\Road Runner\Skins\DigitalFX 2.0\Backgrounds\
    [Radio]
    radiomode=0
    allowallfreqs=false
    radioline=0
    userbds=false
    [XM]
    xmport=0
    xmline=0
    xmlineinplugin=false
    xmtype=0
    singleclickxm=false
    xmformat=%station% %artist%
    [SIRRIUS]
    srport=0
    srline=0
    srlineinplugin=false
    singleclicksr=false
    srformat=%station% %artist%
    [Video]
    videopath=Click here to set path
    mpcpath=C:\Program Files\Road Runner\mplayerc.exe
    videoautohide=true
    videohidetime=4
    builtinvideo=true
    videoshuffle=false
    [TV]
    tvline=0
    [GPS]
    gpsmode=2
    mapmonkeypath=Click here to set path
    gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
    gpsname=iGuidance
    overspeed=55
    gpsport=7
    mappointmap=1
    mapcountry=United States
    mapcity=Tucson,AZ
    mapautozoom=true
    isunits=true
    usegpsserv=false
    gasfinderautorefresh=false
    [IG Native]
    ignative=true
    igautosw=0
    gpsonvoice=true
    pauseonvoice=0
    lastscreenswitchtime=0
    [Speed Att Vol]
    speedatt=false
    [Phidget]
    phidget1=0
    phidget2=0
    phidget3=0
    phidget4=0
    phidget5=0
    phidget6=0
    phidget7=0
    phidget8=0
    [4 Temps]
    tcomport=0
    tempscale=c
    temp1=c
    temp2=c
    temp3=c
    temp4=c
    [Volt Meter]
    vcomport=
    [Phone]
    phoconodesign=false
    motophone=false
    phonelistspath=Click here to set path
    contactspicturespath=Click here to set path
    ringtone=Click here to set path
    smstone=Click here to set path
    maxcalllistentries=100
    phoconoincallevent=false
    connecthsp=1
    standardphonebook=0
    phonebooksencoding=windows-1252
    [Weather]
    cityweather=
    weatherunits=USA
    weatherdegress=
    localdatacaptureinterval=1
    [Extra's]
    player=Winamp
    background=To set path, Click --->
    TransitionTime=0.2
    transparentvisu=false
    opacityvisu=40
  6. #3166
    Jul 2006
    Try deleting ziplocator.dll, or change localdatacaptureinterval=0
  7. #3167
    Dec 2007
    Quote Originally Posted by barnyard View Post
    Thanks, I'll try that tonight.
    Does anyone know of a simple "get started" guide for New RR/DFX installs? Would be a huge help for Newbies , just trying to get up and running. Its taken me a week to find the few Getchas that you must know just to get a screen up. Just a thought. I would be willing to help getting it started...
  8. #3168
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by VettePC View Post
    I would honestly stop with what you are doing. The new DFX is only a few days away from release. Ask all your questions after installing that because everyone will be on the same page. So in the mean time to get yourself prepared for the next release, get the latest flash and DirectX installed on your machine. If you don't feel like waiting, there is a help file with the installation that covers almost everything. I'm sure John wouldn't mind if you contributed to the help file.
    CAN'T WAIT FOR DX3!!!
  9. #3169
    Dec 2007
    Quote Originally Posted by the_crooked_toe View Post
    Yeah, thats what I was thinking, but still, wouldnt it be nice to have a source of at least where and what version to use to get started. Seems the most confusing part for me is what version to use, and where to get them. IE; I have 3 different RRConfig.exe files. Why not have one site to host the set of files needed??? Maybe I'm just too Anal about organization?
    Thanks for the advice.
  10. #3170
    Newbie japeeler's Avatar
    Nov 2007
    Jefferson, Texas
    Beer Fund Donation!
    John,
    I just sent you a donation as promised! Can't for the v3.0 to come out! Really like you skin! Thanks again!
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
