View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #3171
    Nov 2007
    When scrolling through artists/albums/songs, is there a way to make the 'enter' keystroke select the current item? What do I need to change in the skin files?
    Thanks!
  2. #3172
    Apr 2007
    Washington, DC
    disable the double click function for a given song
    is there anyway to disable the double click function for a given song in the audio browser? i only want the users to be able to add a song to the playlist by clicking "add song". the reason for this is if a user accidentally double clicks a song in the audio browser it clears the current playlist. Or is there a way to any ideas? i tried the "play on list click" setting in rr.ini with no luck. Skin is DFX2.5.
  3. #3173
    Jul 2006
    HD TV Possible?
    I have the HVR-1600 WinTV and receive analog signals OK. Is there a HDtv plugin available?
  4. #3174
    Jul 2006
    Reverse Cam
    Maybe I am missing something but - I have the WinTV HVR-1600 and I want to use the Video input for my cam - When I select the camera option in DFx3 beta it displays the last channel I had tuned on the WinTV. How can I get it to display the video input? Also, is there a mod that will automatically detect when the car is in reverse? TIA - I think we need a forum just for this skin since it is so popular.
  5. #3175
    Jul 2006
    FM Radio - HVR-1600 WinTV
    I have spent an hour or so and can not figure this one out. Under the rrconfig/radio section WinTV is grayed out. I've installed the software from WinTV and everything seems to work outside of RR/Dfx3b. Can some point me to a step by step for setting up the FM radio.
  6. #3176
    Jul 2006
    One More - HD Radio Skin/Dfx3b
    The HD radio Skin does seems to be corrupted. I downloaded again with the same result. Any help?
  7. #3177
    Oct 2004
    St. Louis area
    Quote Originally Posted by devin98 View Post
    Got the usage problem figured out, it was actually Winamp taking 99% of the resources. Now I can't figure out how to integrate the case temp and cpu temp at the top of the skin...
    Quote Originally Posted by aplusmiami View Post
    I think it wasn't loaded correctly because it doesn't work for me either.
    Toyota Tacoma Install
    BMW 325Ci Install - Old
    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
    Win 7, RR, Garmin, DashCmd
    Morel Elate 9 3way & IDQ10 ported (active 4-way),
    JL Audio HD Amps, Audison BitOne.1
  8. #3178
    Low Bitrate esko's Avatar
    Jun 2007
    This is the forum for the Digital FX Skin.
  9. #3179
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    It's grayed out because the config looks to see if you have a WinTV folder in your RR folder...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #3180
    Jun 2007
    Quote Originally Posted by VettePC View Post
    Thanks, I'll try that tonight.
    Does anyone know of a simple "get started" guide for New RR/DFX installs? Would be a huge help for Newbies , just trying to get up and running. Its taken me a week to find the few Getchas that you must know just to get a screen up. Just a thought. I would be willing to help getting it started...
    Look for a directory called "helper files" folder in the DFX 2.5 directory. There you will find "DigitalFX Help Documentation"
    This helper file will answer just about everything.
    ENJOY RTFM!
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
