Just solved the non skin change on the fly thing.
autoskinmode=2
Now to fix the album art in the player.
MapPoint
Destinator
Streets & Trips
Other
Tell me more, what is it that did and what were your findings?
Are you too realizeing that skin changes cant be done on the fly?
Are you also experience terrible artwork once you remove X,Mp3Art from the menu.skin JUST to get the artwork to appear again and wile on that same page, you find that next and previous DO NOT WORK?
autoskinmode=2
I solved it myself after looking through the rr.ini thankyou.
Digeratix, I was having blurry/horrible album art so used mp3toys to download high res 500x500 pixel images and create folder.jpg in each folder and this solved my problem of poor album art
No thats not the thing, I have all my album art from amazon.com and its all good. My album art is perfecto. Its something to do with dfx or the mp3art plugin.
Here is my album art examples.
By the way.... I use album art downloader to set embed my albums and mp3's within them.
There are several more buttons on other skins that are wrong.
This is what I found as a solution to your Prev/Next problem on the Audio_Player.skin:
The buttons were coded like this:
B,198,518,99,84,"PREVTRACK",
B,396,516,100,84,"NEXTTRACK",
I changed them to this:
B,198,518,99,84,"PREV",
B,396,516,100,84,"NEXT",
If yours dont have the exact same x/y numbers just find the lines that are close to the x/y's shown here.
That fixed mine.... THEN later I went back and changed the code back to the original and it STILL worked. I cannot explain this.![]()
Good find, mine was
B,198,518,99,84,"AUDIOPREV",
B,396,516,100,84,"AUDIONEXT",
Changed to
I dont understand why its differant than the menu.skin.
XM_Favorites.skin :
POWER ==> scans
IS:
B07,103,510,96,89,"SCANMODE","Scan"
CHANGE TO:
B07,103,510,96,89,"EXITMENU",""
PLAY/PAUSE ==> scans
IS:
B06,297,510,101,89,"PLAY","Play" --Acts like scan
..........TRIED THE FOLLOWING:
B06,297,510,101,89,"PLAY",@STOP||PLAY@ -- SCANS
B06,297,510,101,89,"PLAY", -- SCANS!?
I SET IT TO: (FOR NOW)
B06,297,510,101,89,"EXIT","Exit" -- RETURN TO PREVIOUS WINDOW
PREV ==> loads Mixer window
IS:
B04,200,510,96,89,"MIXER","Mixer"
CHANGE TO:
B04,200,510,96,89,"PREV",
NEXT ==> loads GPS window
IS:
B20,398,510,101,89,"GPS",""
CHANGE TO:
B20,398,510,101,89,"NEXT",
