View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #3331
    Mar 2007
    AZ
    Ok i guess that I am a moron cause I cant get this skin to work. I copied the contents of the RR_Add-2-.ini to the rr.ini file and I am still getting the grayed out skin. I searched this massive thread and didnt really find much. I made sure I had flash installed (used IE to update). I searched some more and found that I have flash version 9 instead of 8 that was recommended.
    1. Where exactly should i copy the 3 lines to the rr.ini file? I tired the begining of the file, then tried under the skin section, and then tried at the end. I removed the first fastmode=-1 entry also.
    2. Do i need flash version 8 instead?
    3. and if im a bigger bonehead for posting this question please just tell me to RTFM again and I will try to sort through it again.
    Dick
    08 Dodge Ram QC
  2. #3332
    Oct 2007
    rydindirty, it sounds like you need to set the picspath/background path
  3. #3333
    Mar 2007
    AZ
    Ok it looks like i am having problems with the version of flash I am using. I downloaded another skin and it is giving me the same issues as with this one.
    I read through the FAQ's for RR and found the flash FAQ but the link for the flash version 8 seems to be jacked.
    edit: does anybody have a link where i can download version 8 so i can change it?
    Dick
    08 Dodge Ram QC
  4. #3334
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    You would feel more of a moron/bonehead (your words) if it's only a matter of setting your picspath/backgroundpath correctly as recommended above!
    Are they set correctly?
  5. #3335
    Mar 2007
    AZ
    Ya I think so. I went back and checked them and set them to the right location
    E:\Road Runner\skins\DigitalFX 2.0\Backgrounds
    and this was added to the rr.ini file under the [skins] section:
    fastmode=-1
    picspath=E:\Road Runner\skins\DigitalFX 2.0\Backgrounds
    localdatacaptureinterval=1
    and I removed the fastmode=-1 from under [general] section
    I found the flash version 8 and made the changer according to the FAQ's and that still didnt fix it.
    Am I adding the lines in the rr.ini file in the wrong place or does that even matter?
    Dick
    08 Dodge Ram QC
  6. #3336
    Jan 2007
    dundee, il
    Quote Originally Posted by rydindirty View Post
    fastmode=-1
    did you check the backgroundpath in dfx2's skin.ini? it should be the first line i believe.
    david
  7. #3337
    Mar 2007
    AZ
    Thanks so much for pointing that out to me. It was defaulted to the C:\ drive. I changed the path and all is good now.
    Dick
    08 Dodge Ram QC
  8. #3338
    Jan 2007
    dundee, il
    glad it helped
    david
  9. #3339
    Low Bitrate VettePC's Avatar
    Dec 2007
    Listen To This One!
    Had things working almost acceptable (aside from my freefone displaying wrong name/picture randomly)
    So, I was adding some things I had put off, IE; Traffic cam, and ability to search albums.
    All was fine yesterday and today,,, then the album artwork stopped displaying in the player. I have been copying my entire Road Runner directory everyday so i had a RECENT backup in case of problems.
    So... I put yesterdays working copy in, and all is ok with album art... UNTIL, I browse and change albums, then album art ok, then go back to first album, and from then on NO art on any of them.
    Did a file compare of my backup folder with current problem Road Runner folder, and I find a file called resume.ini that was not in the the backup folder.
    So, I delete this file and artwork comes back, UNTIL I change albums!
    Here is the contents of resume.ini :
    0
    4822
    False
    False
    C:\Program Files\Road Runner\Skins\DigitalFX 2.0\
    0
    False
    False
    False
    False
    I am about ready to throw in the towel.
  10. #3340
    Dec 2007
    This AM I notice a file in C:\Program Files\ (NOT in Road Runner\ dir)
    called "Road Runnini" (NO ext.). When I remove this file things start working MUCH better. Aside from the occasional first song in an album not showing artwork. (I will live with that). Anyone else have this file? My other test PC with RR does not have it!
    Here is what it contains:
    [Settings]
    HideCaptionMenu=1
    ControlState=1
    DefaultVideoFrame=3
    KeepAspectRatio=0
    CompMonDeskARDiff=0
    Volume=100
    Balance=0
    Mute=0
    LoopNum=1
    Loop=1
    Rewind=1
    Zoom=2
    AllowMultipleInstances=0
    TitleBarTextStyle=1
    OnTop=0
    TrayIcon=0
    AutoZoom=0
    FullScreenCtrls=0
    FullScreenCtrlsTimeOut=0
    ExitFullscreenAtTheEnd=0
    RememberWindowPos=0
    RememberWindowSize=0
    KeepHistory=1
    DSVidRen=0
    RMVidRen=0
    QTVidRen=0
    APSurfaceUsage=0
    AudioRendererType=
    AutoloadAudio=1
    AutoloadSubtitles=1
    EnableWorkerThreadForOpening=1
    ReportFailedPins=0
    DVDPath=
    UseDVDPath=0
    AutoSpeakerConf=1
    SPOverridePlacement=0
    SPHorPos=50
    SPVerPos=90
    SPCSize=3
    SPCMaxRes=2
    EnableAudioSwitcher=1
    EnableAudioTimeShift=0
    AudioTimeShift=0
    DownSampleTo441=0
    CustomChannelMapping=0
    IntRealMedia=0
    UseWinLirc=0
    WinLircAddr=127.0.0.1:8765
    UseUICE=0
    UICEAddr=127.0.0.1:1234
    DisableXPToolbars=1
    UseWMASFReader=1
    JumpDistS=1000
    JumpDistM=5000
    JumpDistL=60000
    AC3SpeakerConfig=2
    AC3DynamicRangeControl=0
    DTSSpeakerConfig=2
    DTSDynamicRangeControl=0
    SnapShotPath=C:\
    AACSpeakerConfig=1
    MpaBoost=1
    LaunchFullScreen=0
    HideAviSplitterWarning=1
    [Commands]
    CommandMod0=32794 1b 27 "" 5 0 0
    CommandMod1=32793 1b 25 "" 5 0 0
    CommandMod2=163 3 4d "" 5 0 8
    CommandMod3=167 b 4d "" 5 0 0
    What is THHIS for!!??
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
