View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #3351
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by VettePC View Post
    but the traffic Cams s a problem. Are there ways to have this data cached in the background until actually clicking on the Traffic cam button to view them? Any thoughts or help would be appreciated.
    If you run the trafficams program at startup it will go and collect the cameras in the background, so when you then select trafficams it will show what is has. It will continue to update the cameras according to the delay set in the ini file, so if you have a slow connection, make the delay longer. (default is 60 seconds)
  2. #3352
    Jan 2008
    digital fx 2.5 player won't go to next song
    I'm using digitalfx 2.5 with the current version of RR. When I go to Music then player and try to use the next song button (>>) nothing happens. When I goto the playlist button and try to use the next button the song pauses. The next button does work on the main screen and gps screen. Any ideas on how to fix this?
  3. #3353
    Low Bitrate VettePC's Avatar
    Dec 2007
    Quote Originally Posted by jollysig View Post
    I had the same problem(s). Back a few pages in this thread you will find the solution(s):
    Read through 3314 where I posted a zip file with 3 skins in it for similar button problems.
  4. #3354
    Dec 2007
    Quote Originally Posted by Enforcer View Post
    Thanks for the info! I tried this and am having some problems... Did you mean put the Trafficcam.skin in the Pr-load setting in RR? Thats what I did. It was working with my cable hooked up(cable broadband connection)... testing now with the I415 MOTO phone that is only doing 21Kbps download speed. I got an error when loading the traffic cams skin. :
    Traffic Cam
    Run-time error '9':
    Subscript out of range
    OK
    I checke din the traffic cams folder and noticed there were cam1.jpg thru cam19.jpg. Could the 19th be the out of range error cause, since there are only three pages avail in the skin with 6 skins each = 18?
  5. #3355
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Camera 19 is the full size camera so it won't be that. (there is allowance for 24 cameras)
    Not sure why you would be getting the error if the install is exactly the same and all you have changed is the internet connection speed.
  6. #3356
    Dec 2007
    Maybe I'll try removing the plugin and re-installing it again. Just hope that doesnt have any weird side effects to something else. I've asked this before, and searched through the registry... but still wondering "how portable is RR/DFX?" Meaning, can I just copy the Program Files\Road Runner directory as a backup and thats it? (of course I know I'd need winamp, Iguidance etc, etc.)
  7. #3357
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    There should be no registry references in either RR, Trafficams or the DFX skin (although JohnWPB mat come along and say he is using the registry)
  8. #3358
    Dec 2007
    Ok, after removing and installing traffic cams the error isnt showing.
    For the most part it works aside from this:
    I am using the Default skin:
    C:\Program Files\Road Runner\Traffic Cams\skins\Default\traffic cam.eskin
    When I click on the "X" button it switches to the Screen that says "If your traffic cams page doesnt load you need to install the internal traffic cams plugin" -- Never recovers from that page...
    Am I missing something in the installation of traffic cams?
    I copied the folder : Traffic Cams 1.2.1\Traffic Cams\ to the Road Runner folder. (deleted current folder first) - clicked on register.bat
    Is there something else needed?
    Also am i correct to understand that "Delay=60" is going to update the prices every 60 seconds, AND "Update=3" is going to check for traffic cams program updates every 3 minutes, seconds, days, or?
    Delay=60
    Country=US
    Skin=Default
    Update=3
    B,670,235,61,76,"CLOSE","" <<== "X" Button
  9. #3359
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Delay=60
    Country=US
    Skin=Default
    Update=3
    The X button is the close button, ie it closes the program down.
    Delay is in seconds and is the amount of seconds you want between attempts to download new camera pics.
    ie
    Delay=60 'waits 1 minute
    Delay=360 'Waits 6 minutes
    Delay =500 'Waits 8 minutes 20 seconds.
    Update tells the program which server to check for updates.
    DFX should have a skin for Trafficams which will probably fit better than the default (BMV2) skin.
  10. #3360
    Dec 2007
    Thats what I needed to know! Thanks.
    Not sure why it hangs on the loading traffic cams instead of closing... But, I guess its ok, since the Home button works from that screen.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
