View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #3591
    Oct 2007
    Blue ZX3.. I need to check that I am not sure what I have it set to I will check when I go to my car at lunch thanks..
  2. #3592
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by dmistry View Post
    I am running the 12-06-07 binary version downloaded from Guino's website..
    In your rr.ini make sure the line "localdatacaptureinterval=1" appears.
    On a side note the other thing I have noticed now that I have my Siruis hooked up and working is that the Signal Idicators do not report anything..
    Nonworking signal indicators are a known issue in DigitalFX 3.0 beta.
  3. #3593
    Oct 2007
    Quote Originally Posted by digeratix View Post
    Save my EQ settings?
    Top Previous Next
    To use the EQ, you will need to open it, and adjust the EQ to your liking. If you are listening to say a Rock song, adjust the EQ settings until they are too your liking. When you have done that, you then press and HOLD one of the buttons for two seconds, Rock in this case. This will save the current settings to that button. You will need to do the same for each button that you want to configure.
    TIP: Instead of starting from scratch each time, You can tap the Rock button again, to start from there, and just adjust so there is more bass for instance, and save that for the "Rap" setting by holding that button down for 2 seconds.
    That was taken from the help section of DFX2.
    How can I be certain the change is happening? I think I followed the directions pretty good and it doesnt reflect any change when I select differant eq settings.
    I have a little issue with winamp eq setting not save too, hope someone could hlep. I followed instruction hold the button for more then 2 second to save, then I select other button and go back to previous one, the setting is not save. please advise.
    Oct 2007
    thanks for all the info.. I wil be trying this out tonight
    One other thought does the 'zips.dat' need a DLL? and does that DLL need to get loaded registered? or something?
  5. #3595
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    There is an ziplocator.dll file but DO NOT use as it hasn't worked with the last couple of rr releases. rr will just use its internal way if that dll is not present.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #3596
    Oct 2007
    ok so I downloaded the zips.dat file and I will put it in the RR root directory and the GPS location should start working right..
  7. #3597
    Raw Wave
    Jun 2002
    Virginia
    You said in post 3590 that zip.dat was already there. No matter what you do, it will not work unless you have "localdatacaptureinterval=1" in your rr.ini.
  8. #3598
    Oct 2007
    I did have the zip.dat but the one I downloaded as part of the RR_INSTALLER was quite bigger in size. So once I put that version in and verified the localdatacapturelevel=1 everything started working, including the GPS weather updating..
    Only one problem though the CPU is now 100% all the time it was always around 9% before!
    *SIGH* is this also a known problem I missed?
  9. #3599
    Raw Wave
    Jun 2002
    Virginia
    There is no way the zip locator should be causing anywhere close to 100% cpu usage.
  10. #3600
    Oct 2007
    thats the only change i have made I guess I should try and rename it and see if the CPU usage drops
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
