View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #3611
    Oct 2007
    May be he will release his code/psds or whatever! *wishful thinking*
  2. #3612
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by dmistry View Post
    *wishful thinking*
    My Fiero Build Thread
  3. #3613
    Oct 2007
    atleast it drew you out John!
  4. #3614
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Freefone problem solved
    Quote Originally Posted by mnwcsult View Post
    My last two post sum up the problem no response from CDRskul
    http://www.mp3car.com/vbulletin/road...runner-18.html
    I have come upon the solution by rereading the in file instructions about dialing strings
    #### Answer and Hangup AT Commands, use *** to show where the dialed number should be.. ie ATD150; is ATD***; ####
    Answer=ATA
    Hangup=AT+CHUP
    Dial=ATD**********; <<<<<<< I have too many stars
    The Instructions clearly show ATD followed by (3) ***, my interpertation was a * for each number in a telephone number, as the example showed ATD150 3 digits.
    Actually *** is the placeholder for the dialed telephone number. Where the entered telephone number will be substituted for the placeholder ***. And the placeholder is always three *.
  5. #3615
    Jul 2006
    Exclamation iG Menu off center
    Quote Originally Posted by barnyard View Post
    Ok, I've had this problem for a while, and I'm not even sure where to start... see the below screenshot, all of the iGuidance menus are shifted to the left, and cut off. I'm running at 640x480, and everything else works, just the menus are screwy. Any suggestions?
    Just incase someone else has this problem, I figured out what was causing it. I had the windows taskbar on the right side of the screen because it's easier to "click" on an 8" touchscreen. The taskbar was shifting iG's menu over the width of the taskbar.
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  6. #3616
    Jun 2002
    Virginia
    Kbreeden, so this morning I get in the car and do a restart from the resume and can you believe the CPU issue went away and I now have GPS location working.
    Glad to hear it.
    One final thing to solve and I should have a fully working system, I have tried a bunch of things to get the volume to lower when GPS is speaking like setting the GPS volume higher than the master volume etc. STill does not work any ideas on this one?
    There's been a lot of discussion of this and I'm not sure the cause has ever been determined. I had the problem also and was pulling my hair (what's left of it anyway) out trying to figure it out. Finally, I did something - I have no idea what - and it has worked ever since. Best as I could tell, there was some sort of conflict between how Blue's RRConfig and the DFX skin were handling this. I can't remember for sure, but it seems to me that Blue may have recently updated his RRConfig program to address this somehow. Maybe Blue will chime in or you can review the last couple of pages of his RRConfig thread for some insight.
  7. #3617
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Cough...
    yes the last config update, I took out the igpause stuff, b/c too many users having probs.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #3618
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by kbreeden View Post
    The master JohnWPB don't agree but i also believe the above is true - you have to chose which either RRConfig or DFX you want to handle that function. I chose RRConfig and disabled DFX's (in ExcTBL) and all work fine. There are a few tweaks you got to do to IG's volume, the wav volume and the main volume but in the end it work fine. There is a thread about that but i don't remember where.
  9. #3619
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You don't know John very well then do ya...
    Just be patient people...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #3620
    Oct 2007
    i'm itchy
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 12:02 AM
