View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 4 of 376 FirstFirst 123456789101112131454104 ... LastLast
Results 31 to 40 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #31
    Sep 2006
    Sabattus, ME
    the question that needs to be asked is how do you use regserv32. I doubt many people know how (aka non power/super users!). so an explanation would be in order.
    CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
    Powered By Road Runner & DigitalFX Skin and Playlist Conveter
  2. #32
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Arrow regsvr32 to register a .dll or .ocx component
    ok to register a file: (Was just a skin, now computer lessons, I charge double for this )
    Get to a command prompt (Start, choose run and type cmd and click ok/press enter)
    Browse to the directory that road runner is in using this command:
    Code:
    cd c:\program files\road runner
    Once in the directory type:
    Code:
    regsvr32 mp3art.dll
    You will get a confirmation that the dll has been registered with windows, and you are good to go.
    BTW, Sangre, your Signature is SOOOoo Old school
    My Fiero Build Thread
  3. #33
    Sep 2006
    Phoenix Az
    I tried to register mp3art.dll, everything was ok, but the embedded art still not working, do i need also to add that command in the main menu? or you already did that? I checked the embedded art with centrafuse, and ot's working fine, for some reason it's not working under road runner.
  4. #34
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    let me look into it here and see whats going on....
    Here are the instructions from Giono:
    1- Copy MP3ART.DLL to install location (of your choice -- DO NOT MOVE IT AFTER STEP 2!)
    Done
    2- Regsvr32 MP3ART.DLL
    You did that
    3-Add: X,Mp3Art to menu.skin of desired skin
    It's in the skin, as I just checked it
    I will do some further testing by removing images from some of my folders ect.
  5. #35
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    Quote Originally Posted by JohnWPB View Post
    Kbreeden, thanks! That reminds me of something else concerning this with the Playlist path. Check the Help file under How Do I save Playlists. There are detailed instructions in there on how to get it all working. There is a bug in the RR.config utility that will not save the path, even if you put it in there
    Thanks JohnWPB & Kbreeden. The playlist works great now! I also was able to set up your super search skin & it is incredible!
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  6. #36
    Low Bitrate swwesq's Avatar
    Dec 2006
    Skin is GREAT! Quick question John or anyone else who may know. I followed the instructions to add the spectrum analyzer as my visualization. It worked great at first, now when I hit visualize the analyzer will never show up in the box. It seems to end up where I last left it with winamp open without RR. I added the !Winamp Gen!AVS to the AVS window title, but I can think of anything else.
    Ideas?
    Thanks,
    Steve
  7. #37
    Nov 2004
    St Louis
    Quote Originally Posted by swwesq View Post
    This is one of the issues I also have with the vis and discussed it with JohnWPB when first released. Embedding doesn't work as normal with this vis. You can only move the vis around when running Winamp stand alone, so you basically have to guess where it need to be and then use trial and error to get it in the exact spot needed for the skin. This vis is the only one I've used that doesn't embed within the confines of the embedding area.
    Another issue with this vis is if you use more than one skin, its location is ofset from the embedded area but the sizing is right - strange.
    Again, if this is the only skin you're running you need to go back and forth from RR to Winamp adjusting the location of the vis till it matches with the album art, then you never have to touch it again.
  8. #38
    Oct 2006
    CT
    Great Work!!!
    Bugs i have found so far:
    - autoinstall script doesnt seem to work right, got the same error as reported earlier in this thread
    - GPS i am running MS S&T 2007, blue window covers the front, and once S&T comes up, RR menu goes in the back.
    - Logo is showing up to be all white, can't change the logo, seem like the filter for extention might not be set right.
    - Settings skin, doesnt seem to do much as to what its suppose to.
    - RR Config doesnt launch
    - Control Panel doesnt launch
    - Wireless Network, Bluetooth, and Display Settings dont seem to do anything.
    Thats all i found so far, will test more tomorrow.
    looks nice, good work, wish i could do all that with flash(i think thats what u have used)
  9. #39
    Sep 2006
    Phoenix Az
    RR config, control panel launches, works fine for me , i just still can't figure embedded art thing
  10. #40
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Spectrum analyzer not embedding correctly
    Ok, the spectrum analyzer embedding has definitely been an issue, that I didn't have myself, until recently. After I installed the Jump to track plugin, and updated the JTT winamp plugin, it started happening. I was going nuts here trying to figure it out! I finally uninstalled Winamp, and reinstalled it and all went back to normal. It SEEMS to be connected to the JTT feature somehow.
    Can anyone else confirm if this seems related to when yours stopped working, of if you had installed this prior to trying to skin?
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
