I have the Car2PC interface running, so that when I press a button on the radio the playlist in winamp will change.
The problem I'm having is that the change in playlist is not reflected in the skin.
Is there away to show the correct playlist?
MapPoint
Destinator
Streets & Trips
Other
Downloaded fine. Installed on desktop w/no issues and will be installing in Car in a few hours...
As always, thanks for the hard work on your contributions!!!![]()
Alex
Progress: 91% (Cosmetics) @ Stand Still...
CarPC specs are BACK!! Edit yours today...
Sorry man, thats beyone me at the moment. I have never used the Car2PC interface, and really know nothing about it. It sounds like when a button is pressed, and a command in RR is activated, that a refresh command should also be sent to the skin as well somehow.
From the Skincommands.ini file:
"RELOADLIST" - Reload Winamp's Playlist onto playlist (in case external applications/winamp changed it)
My Fiero Build Thread
I did receive an VBscript error using the installer (can't recall the exact message). However, it did seem to install itself and is running well with no visible errors. I especially like the configurable weather presets on the top of the weather screen.
Good job!
Alex
Been down due to an accident to my arms, but im good to go now.
So after finaaly being able to be independant ive work on installing this skin, that happens to be very nice by the way. Been tring to load the logo but the menu button doesnt work. everything seems fine until then. Just when i click on menu to load and return to the music screen....nothing. I have to exit out and back on and then the logo,s were loading up in the playlist one at a time.
If you cant DODGE em, RAM em.
Man, I'm sorry, but I have no clue to what you are asking, you mention the Logo, Menu button, Music Screen, and Playlist... thats 4 separate things. Can you tell me a little more about what is happening?
Someone asked me for the PSD for the XM Favorites skin, and I can't remember whoAnyhow, it is now on the same site as the skins. linked in the first post. To make your own custom buttons, just use the blank template to start with, and use the XM/Sirius logo's that are in the XMart and SRart folders. If you have not used Photoshop that much, when you load one of the Gif's to use as a button, you will need to change the Color to RGB By going to the Image Pulldown, Mode, then selecting RGB. Otherwise it will not allow you to drag the gif logo's onto the skin template.
As for the logo's not working, I am not sure what the problem could be. They are working here correctly. I select one from the list, and click Change (DO NOT DOUBLE CLICK THE LOGO IN TH LIST), and when I go back to the main menu, the logo has changed.
EDIT: I just saw this question posted in the main thread area, and maybe see whats wrong. When you click a logo in the list, you must then click the CHANGE button on the right to actually change to that logo.
