View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 47 of 376 FirstFirst ... 37383940414243444546474849505152535455565797147 ... LastLast
Results 461 to 470 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #461
    Dec 2006
    Quote Originally Posted by kbreeden View Post
    Civic, I'm curious whether it was working okay before you loaded Xport. I'm using Xport also and don't think it should be related, but one never knows.
    Kbreeden and Civic - are you both sure that you have IG and RR set to use the output ports you have configured in xport?
    Kevin
  2. #462
    Jun 2002
    Virginia
    Quote Originally Posted by klundy View Post
    Kevin
    Yes, my iGuidance runs just fine outside of RR.
  3. #463
    Dec 2006
    Doesn't necessarily mean it is set right. Remember, RR can also receive data from the GPS. So if they are both using the same port, RR would grab it first. I've also had one instance where xport seemed to drop one if it's output ports.
    It's at least worth double checkin.
  4. #464
    Jun 2002
    Virginia
    Checked it out. iGuidance does work inside RR once I load it from the GPS button; it's just that it gives me the warning when it loads and doesn't embed properly. It also gives me the "iGuidance has encountered an error" message whenever I open or shutdown RR. Very strange as all was working well before the latest DigitalFX upgrade. I have now totally reinstalled RR and DigitalFX and no joy.
  5. #465
    Dec 2006
    BROOKLYN NY
    i just installed the digital fx and am having a problem streets and trips 07when i load fx street and trips is loading too any1 having that same problem...
  6. #466
    Jun 2002
    Virginia
    Tried it with LSXVoid and same problem with IG. Deleted RR.ini and tried again without improvement. The only other change is that I did download the newest version of Road Runner.exe per the link in post 1. Could that have anything to do with it?
    Civic, did you re-download the newest version of RR per the first link also?
  7. #467
    Dec 2006
    I've downloaded the RR beta and it worked fine with IG. I'd double check for you but my laptop is in pieces in search of a place to solder w3bmast3r's power on module.
  8. #468
    Jun 2002
    Virginia
    What I don't understand is why IG is trying to load when RR loads. Did it do that in earlier versions of DigitalFX?
  9. #469
    Constant Bitrate megagoo's Avatar
    Oct 2004
    Loaded the new release in my car and I'm getting a "iGuidance encountered an error and must shut down" error every time I load RR. I can then hit the GPS button and it will load iGuidance, but the warning message comes up and the iGuidance window doesn't embed properly in the skin. I inadvertently deleted my rr.ini when I did the reinstall so I'm wondering if my rrconfig settings are now wrong. GPS is set to external and window name is iGuidanceUMPC. Any thoughts?
    same problem here. im using Xport and have been for a few weeks just fine with the last skin version.
    its not the RR.ini .. i went back to the old skin and no error. when i switch to new skin it gives me the error
  10. #470
    May 2006
    I am encountering the same iGuidance errors with 3/1 upon loading RR. Worked ok before 3/1.
    I also encountered a problem with the iGuidance configuration panel invoked by "Auto Config". It appears to me that the pushbuttons are hard-wired for c:\Program Files\Road Runner\IGScripts\etc. I have RR installed on the D: partition and it is so noted in RoadRunnerPath.ini. Is there another .ini file that I have missed? I copied the iGScripts folder to c:\Program Files\Road Runner\ and tried again, getting errors on 2 of 4 buttons.
    Can one minimize the full-screen iGuidance skin so as to get at music controls in DigitalFX while iGuidance is running? I no longer see the column of DigitalFX icons on either side of the iGuidance map. Can one select between full-screen and not full-screen iGuidance?
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
