View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 5 of 376 FirstFirst 12345678910111213141555105 ... LastLast
Results 41 to 50 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #41
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Zeeshan0581 View Post
    Great Work!!!
    Bugs i have found so far:
    - autoinstall script doesnt seem to work right, got the same error as reported earlier in this thread
    - GPS i am running MS S&T 2007, blue window covers the front, and once S&T comes up, RR menu goes in the back.
    - Logo is showing up to be all white, can't change the logo, seem like the filter for extention might not be set right.
    - Settings skin, doesnt seem to do much as to what its suppose to.
    - RR Config doesnt launch
    - Control Panel doesnt launch
    - Wireless Network, Bluetooth, and Display Settings dont seem to do anything.
    Thats all i found so far, will test more tomorrow.
    looks nice, good work, wish i could do all that with flash(i think thats what u have used)
    Shew!
    Ok.... lets tackle this list:
    - autoinstall script: As I mentioned, can you give me any more information on the error? Exactly what it says ect?
    - MS S&T 2007: I do not have S&T 2007, just 2005, so I am not sure whats happening there.... will see if I can find out whats going on.
    - Logo is showing up to be all white: Check the Help file under "Clock Logo" is showing up as white
    - Settings skin, doesnt seem to do much as to what its suppose to: As mentioned in quite a few posts here in the thread, you have to add .exe to the file types for music in the RR Config utility to see the list of available logo' sif that is what you are refering to.
    - RR Config: It is launching and embedding here fine, as well as for other users, possibly something with your specific machine / setup
    - Control Panel: Same as above
    - Wireless Network, Bluetooth, and Display: Same as above
    My Fiero Build Thread
  2. #42
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Great skin.
    I'll shoot you some paypal when I get my paycheck...
    Rafster
  3. #43
    Jun 2002
    Virginia
    Great Work!!!
    I don't use S&T, but everything else you mentioned works perfectly for me. You may want to try a fresh install and then for the logo follow the instructions in the help file as JohnWPB mentioned.
  4. #44
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Rafster View Post
    Great skin.
    Rafster
    Thanks Rafster, its always appreciated!
    Thanks for the confirmation kbreeden, I had about 5 people going over the skin with a fine tooth comb, you being one of them, and none have reported that particular problem. The final tester, Liquid Smoke, only found a couple minor issues, that have been fixed.
    This DOES NOT mean the skin is 100% yet, as not all people have all hardware & software, the case with S&T 2007 a couple posts ago is a good example of that. SO keep the suggestions, bug reports and problem reports coming in!
    BTW, I just spent a couple hours brushing up on my reading and writing to ini files in VBScript. The new installer will look to see if you have Road Runner installed in the default location (C:\Program Files\Road Runner\). If not the installer will tell you to edit the RRPath.ini, and re-run the installer.
  5. #45
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Arrow New Version is posted
    Ok new version is up in the first thread... some minor bug fixes ect.
  6. #46
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Feedback?
    I was hoping to get more feedback from the masses here. The skin has been downloaded around 150 times, and just like 15 different people have posted in the thread.
    I DO appreciate the comments, suggestions and bug reports so far, but there are far more people using it, and I could use that input as well
    I want some feedback on anything that needs fixed, improved on ect. I want to get as much done to this before I start finalizing the other colors, so I don't have to go back and edit each of those individually.
  7. #47
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    The installer still isn't working for me. I've installed RR at c:\road runner. I've changed the path in roadrunnerpath.ini. But when I run the installer i get the error"
    Roadrunner is not installed in the default path: c:\road runner\
    Please open the RRPath.ini and put the full path to Road Runner on your system. WHen you have done that, run the installer script again.
  8. #48
    Aug 2003
    Federal Way, WA
    and I'm having problems with the AVS file. I can't seem to get them to work in Winamp by it's self. I got one to work but when i right click on it to edit it nothing happens.
  9. #49
    Jun 2002
    Virginia
    Quote Originally Posted by JohnWPB View Post
    I was hoping to get mre feedback from the masses here. The skin has been downloaded around 150 times, and just like 15 different people have posted in the thread.
    John, maybe it's just that it's that good. Usually people post only if there's a question or problem. In this case,though, it would be equally helpful for people using the skin to post saying that they're using it and not experiencing any trouble. That way you'll know it's in pretty good shape and can feel comfortable implementing the new colors.
    So those of you happily using the skin without any trouble, please help out and make a post saying so.
  10. #50
    Oct 2006
    CT
    JohnWPB,
    i fixed the logo issue, needed a newer version of flash.
    GPS i am using iGuidance 3.0, working like a charm. One issue though, whenever i start GPS for the first time, it doesnt start as maximized, i have to click the double window button under 'Repeat Command' button for it to fix it.
    I still cant get Control Panel, wireless settings, bluetooth settings, and display settings to do anything inside settings option, probably something with my system.
    Is there a way to stop the system beeping every time i use touch screen, anyone else getting the beep?
    Would love to see a Silver Version of the screen..... whenever you get to it.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
