MapPoint
Destinator
Streets & Trips
Other
Just installed the skin, great works & 2 thumb ups!!! JohnWPB
Only problem I find out is illegible international letters (Thai, in my case) displaying on the top of each sub menu. It displays correctly in Digital FX main menu and playlist. Any suggestion?
i would say make sure you have the following directories:
\DigitalFXBlue\Road Runner\Skins\DigitalFX Blue\Menus
\DigitalFXBlue\Road Runner\Skins\DigitalFX Blue\Logos
if thats confusing, the directory with all the .skin files is:
so in the dir with all the jpgs for the menus and .skin files, you should have a menus and logos folder, not to mention folders for flash, scripts, slider battery, temp, vid capture, and weather
eddie
John, thanks for posting the XM favorites PSD. It makes it a lot easier to get around in XM.
Boriman, Wow! Thats a lot of trial and error to get your picture posted!
Boriman, Sylad & Jared:
Are you guys using the LATEST RR, that the link is posted to in the first thread? It looks from here that you are not, as the .png files are not showing up in the directory list, and JUST the .exe file is. I am wiling to bet this is the problem.
From the first post, right under the download link:
As for the font problem, Install the font that came with the DigitalFX.zip file. I will make sure that is corrected here for the next release.NOTE: You MUST have the latest RR Beta (01/22/07) for some of the new features to work. You can download it HERE (Just download the Road Runner.exe and replace your current one with it.
Glad the PSD's helped you out.
My Fiero Build Thread
I'm having problems installing this skin. I get the following error messages
Script c:\Documents and Settings\...\Install Digital FX Bluel.vbs
Line 192
Char 43
Error Path not found
Code 800A004C
Source Microsoft VBScript run time error
I then tried to install again and got a different error but similar
Line 190
Char 44
Error File not found
Code 800A0035
I have tried to install this on my carputer as well as my laptop (HP livestrong w/AMD turion ) I tried the brushed metal color am I missing something? I did install Liquid Smoke ok but wanted to try this skin also.
I needed to do it manually (no biggie, instructions are good). For some reason I couldn't get the automatic install to work, get a .vbs error. I did follow and retrace the steps, and just did it again. Made sure the weather folder was where it belongs, even swapped out the old images for the new and back. Same thing. Maybe because I am doing it manually?
The maps work, I'm wondering if it's a RR config problem, or maybe the PC itself? What would cause the auto install to stop before it starts?
I thought the latest release for RR was 03/01...
Working on - 2006 Cadillac Escalade with all the TOYS!
COMPLETE! - 2002 Cadillac DTS - Summer 2008 - SOLD SUMMER 2010
COMPLETE! - 1998 Cadillac Deville Concours - Summer 2007 - SOLD SUMMER 2008
I just downloaded the updated skin in BM format. The installer didn't work for me again (same error as posted above) so I installed it manually and it appears to work. However I have a few issues:
1. The flash on the GPS stats screen still does not work properly (the speedo still does not work right). Did I miss something in the manual install?
2. I could not find the "AddtoRRini.txt" file to help speed up the skin as you stated in the original post.
3. I also noticed in the BM skin that the DigitalFX setup screen does not match the one posted above (I noticed that you changed the skin a bit since the last release).
Thanks and keep up the good work!
First I would like to say what a wonderfull and fully intigrated skin this is!! Please keep developing this one!! My favorite!!
Some input. and a few questions.
I too am having trouble which the script installer
line 201
char 40
error Path not found
code 800A004C
I have installed it manually
I am running the latest Blue skin with March 6 2007 beta road runner on windows 2k
I am also wondering how to setup Canadian weather locations is this done in the config or in an ini file and what do I put for Canadian locations?
I have iguidance 3 how do I get this working with your skin? I have the latest script enhanced UMPC version which I replaced in the inav directory put the theme.ini file there as well. used the rr config and replaced the path for mapmonkey and used the external source radio button.. can't get it working?
Once again this site is a wonderful resource for a budding carputer builder. thanks for all the great info.
Paqman
