View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 53 of 376 FirstFirst ... 3434445464748495051525354555657585960616263103153 ... LastLast
Results 521 to 530 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #521
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    guys, the only installer and skin that is complete right now is the Blue one. I am trying to get that one working 100%, and will port the scripts and such over to the other colors soon as I can get to it.
    What you can do, is install the blue skin, and then copy over all the images and such to the blue folder. There may be a few images that are not completed in the others colors, so when you go to recently created screens, the blue image may still show.
    As for Canadian weather, you can try to see if this works "CAXX0504" That is Toronto. I went to weather.com, and copied the location in the address bar. I can't test it here, as I do not have RR installed. Doing a complete reinstall of the OS and everything here.
    My Fiero Build Thread
  2. #522
    Mar 2007
    Help carpc down!!!
    First of all thanks for the Digital Fx, but I have a problem (maybe a stupid one) I downloaded the BLUE DigitalFX. Cannot get skin on screen. I'm using a 7" touchscreen (Lilliput) and my desktop : OS= XP pro, Memory= 1gig, video= radeon 7000, Hard drive= 300gig.
    New at the game....
  3. #523
    Constant Bitrate megagoo's Avatar
    Oct 2004
    what happens when you double click the roadrunner icon? do you have the correct skin path set in it? e.g. c:\program files\road runner\skins\digitalfxblue or something.. you want to point it to the directory with all the .skin files
    are you sure you downloaded the update? go to satellite radio and it should say under "favorites": hold for icons ... or something like that. the old version just said favorites on the button
    Quote Originally Posted by jmciver View Post
    I just downloaded the updated skin in BM format. The installer didn't work for me again (same error as posted above) so I installed it manually and it appears to work. However I have a few issues:
    1. The flash on the GPS stats screen still does not work properly (the speedo still does not work right). Did I miss something in the manual install?
    2. I could not find the "AddtoRRini.txt" file to help speed up the skin as you stated in the original post.
    3. I also noticed in the BM skin that the DigitalFX setup screen does not match the one posted above (I noticed that you changed the skin a bit since the last release).
    Thanks and keep up the good work!
  4. #524
    Nov 2005
    Quote Originally Posted by megagoo View Post
    The skin files are in the right directory and load fine. I did download what I thought was the updtae in BM format. However, John stated above that the only color that has been updated was Blue for now.
  5. #525
    Apr 2005
    So, i have a problem......rather small......inside IG when I click the button to show the music titles, it is just a white bar with no text. Any ideas?
    And the guages work great but I still cannot get it into MPH.
  6. #526
    Feb 2007
    PA
    Quote Originally Posted by kbreeden View Post
    Darro, go into RRConfig, click music and add ".m3u" (no quotes) to the audio file types box. Please let us know if that fixes it.
    Sorry for not replying sooner - this took care of the problem! Works perfect now - thanks so much!
    Still can't get imageviewer working though, is there a config i missed for it?
    Quote Originally Posted by darroj
    I'm also having problems with imageviewer. is there a file size/resolution constraint? when i go to imageviewer, the screen reamains black... (images are located within my documents -> my pictures)
  7. #527
    Jan 2007
    Hey hows it going? John youre awesome. Digital FX is still running great on my machine. Only have a few problems. I have looked for fixes for them, but this post has gotten so long.
    Media Player Classic freezes RR often and wont play some avi/mpg files that WMP10 will play. Is this a known issue?
    How do I get Internet Explorer to open when I click on the internet button?
    How do I get the GPS stats and compass to work? I have tried changing the port in rrconfig to the port for my gps device, but it always resets back to 0 on its own.
    Also how do I change the city for the weather to my city and state?
    Finally I have the same problem with font. Its usually just a couple of characters infront and behind the id3tags.
    My next step is to install the latest update digital fx. I have the updated rr.exe
    Thanks everybody.
  8. #528
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by darroj View Post
    Both issues you are having are actually in the help file.
    "How do I Use Playlists"
    "How do I use the Image Viewer"
    Look under those title's, and it will explain how to get the image viewer to work.
    Quote Originally Posted by MrCummings View Post
    Thanks everybody.
    MPC Freezing: This is usually a Codec issue. Google K-Lite Codec Pack, installing that package of Codec's has worked perfectly for me.
    Web browser: You need to open RR Config, and choose the path to the web browser you want to use.
    Weather Cities: As stated in the help file, press and hold any of the buttons on the top of the weather screen to change the city.
    Fonts: this sounds like a unicode issue. Those characters are actually saved in your MP3's. Do a search on the forums for unicode and you should find some answers.
  9. #529
    Low Bitrate swwesq's Avatar
    Dec 2006
    Traffic Plugin
    John, I would be willing to donate again if you would be willing integrate the Traffic plugin to your skin.
    Thanks,
    Steve
  10. #530
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    Quote Originally Posted by swwesq View Post
    Thanks,
    Steve
    Yes, I would like to donate more "Beer" money, as well. Waiting patiently for update to brushed metal skin....
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
