Thanks John, I just ordered one off of ebay. It's kind of funny that the new one you can get cheaper off of newegg than what the original costed me on Ebay. I didn't care about the price, I was just happy I could find one.
MapPoint
Destinator
Streets & Trips
Other
evrything works fine, except the return to digitalfx button, insyead of going back to menu1 of digitalfx it brings up the exit menu (restart,hibernate,cancl etc)
also when i now start rr it loads up then it loads my gps (freedrive) over the top of rr
I use iG3 myself for GPS so I'm not positive, but I did have this same problem before I used the correct window name in the rr.ini file. For example, I was using "iGuidance UMPC" because I thought that was it and had the problem, when in reality it was only "iGuidance". Once I got the window name correct it embedded perfectly.
GeorgiaCarry.org Member
got freedrive to return to digitalfx without exit screen,
its abit hit and miss really but like john said earlyier on he has done his best on the skin.
checked window name with winspy and all is correct, only problem still is it loading over the top of rr when i start rr, is there any way i can get it to load behind rr , it seams to me that there is somthing in rr that starts your external gps program when you start rr, all so when i hit gps button in music player screen , it loads into the screen no problem switch back to visualisation no problem go to gps from main menu freedrive gone no screen, shut rr and freedrive start up again freedrive loads into music player size window not full screen , have to reload freedrive to get it back to full screen,how it should be
Nice job on the skin... I'm testing it out and ran in to two issues. I tried to read the whole thread but it's gotten pretty long (got halfway through!).
I'm using the copper version and just downloaded it along with the new rr.exe you linked to.
I have the sirius module hooked up which works fine with LSX 2.0 skin. When I click on "Sat" radio I get an xm page that has my mp3's listed instead of channels. How can I get sirius working properly?
Also, I tried to change the logo to nissan z and I followed directions like in the help file and this thread but it doesn't seem to change and stays on the mitsu logo. Any ideas?
Finally, for some reason my mp3's are showing up as just song name, no artist or album. They are properly tagged.
Thanks!
I haven't had the full time to go through every post here, so please don't blast me. (or if you do please make it harsh) When I use digitalfx blue or copper my GPS receiver has a problem being found. (IG3.0+Microsoft 360 gps) I can load RR with Blue devil without this problem. I also downloaded the new IG exe you had in an earlier post and loaded using that. I still get the same problem. I'm also using the updated rr.exe you had posted. I also added the mung to the rr.ini
Error: Please make sure GPS receiver is plugged in correctly. (only with Dfx, not blue devil nor default RR skin)
P.S.
This skin is the greatest. I've been using Blue devil for a while now and enjoyed that as well. Keep up the great work.
Is that what you really meant to say?![]()
It sounds like RoadRunner is grabbing your GPS receiver so your nav can't use it, though if that were the problem I don't know why everything would work with Blue Devil. Are you using a port splitter such as Xport3? Does your speedo work in DigitalFX when your nav is not working?
LOL. You gotta respect a guy that doesn't mind taking a beating - sort of like Paul Newman's character in that famous fight scene in Cool Hand Luke.
Anyway, this is perplexing because if it works in Blue Devil it should work in Digital FX. I assume both skins are in the same Road Runner folder so they're both using the same rr.ini. You said you're not using a port splitter. In that case, both the speedo and your nav can't be working in Blue Devil. Are you really sure they are both working?
No the gps used to work, however the GPS data screen (in fx and blue devil never worked) Maybe they are conflicting now?
