View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 66 of 376 FirstFirst ... 16565758596061626364656667686970717273747576116166 ... LastLast
Results 651 to 660 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #651
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    It's possible that you have 2 instances of iGuidance running. I added some code in the autoexec.tbl file for personal use, and forgot to take the line out before releasing the latest version. Look a couple of pages back in this thread, and there are instructions to fix it.
    Also take a look at the DigitalFX Help file, under "How do I use the GPS gauges / more than one GPS device"
    My Fiero Build Thread
  2. #652
    Jun 2002
    Virginia
    Quote Originally Posted by Buggy-G View Post
    No the gps used to work, however the GPS data screen (in fx and blue devil never worked) Maybe they are conflicting now?
    Yes, they are conflicting but at least one of them (GPS or Speedo) should work in DigitalFX. You need to do the following:
    1. Download Xport3 (attached).
    2. Open iGuidance outside of RR. Go to Tools/GPS Options/Autodetect. This will tell you what port your GPS Receiver is using.
    3. Load Xport3. Go to the input section and choose the com port determined in 2 above. Then go to the output section. In the first output block choose any available com port from the list. Remember the number because it will be the com port setting that you use in iGuidance. In the second output block pick any other available com port. Remember the number because this will be the GPS setting that you choose in RRConfig. Click the enable service box. Leave Xport running (you should include Xport.exe in your startup folder so it always loads upon startup).
    4. Open iGuidance outside of RR. Go to tools/GPS options/Com Port. Designate the com port number that you chose in the first output box of Xport. Exit iGuidance.
    5. Open RRConfig. Hit the GPS tab and in the box labeled "GPS Port" type in the number of the com port that you chose in the second output box of Xport. Save and exit RRConfig.
    In a typical scenario you should now be able to run iGuidance and the speedo in any RR skin. I have found Xport to be finicky at times so you may have to open Xport and just make sure it is shown as enabled and everything seems to be working. If Xport is receiving the information from your GPS receiver the NMEA data will be shown scrolling at the bottom.
    If the above doesn't work then it might take a better brain than mine to figure it out.
    Attached Files Attached Files
  3. #653
    Aug 2006
    I'm going to try this tonight, I think thats what it is, because on this last trip I made (10 minz ago) the speedo worked but not IG. Thx a ton for the help and information. And as always Thx for the great Skin.
  4. #654
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Can't install RED nor BM
    I'm getting an error when trying to install the Red or BM DigitalFX. After some searching, i found reference to the problem and i seam to understand that by downloading the latest archives the installer would be fixed..well, i just downloaded and tried to install but the problem still persist.
    The DigitalFX Red folder appears in the RR skin directory but there's only a temp folder within it.
    I saw where it mentioned to install a beta version of RR but i didn't since the version i have now is newer..maybe i should!
    I also saw where you had to "comment-out" a couple lines but i don't think it applies.
    I also downloaded and installed the VB runtimes from Microsoft.
    Instead of going through all 40 pages in this thread, i figured i take the heat and hope somebody would feel sorry for me and eventually point me to the answer..
    Thanks for any help.
  5. #655
    Jun 2002
    Virginia
    Quote Originally Posted by treetop777 View Post
    As much as I'd like to help, John is probably the only person who can address this one.
    By the way, for all of you who love this skin please show your appreciation by making a small donation to John as shown in the first post. He has put literally hundreds of hours into this and goes out of his way to help people with their issues. Not only that, he uses donations he receives to help purchase additional equipment that he needs to add capabilities to the skin.
    (Sorry, John, I know you'll be aggravated with me for posting this. )
  6. #656
    Mar 2006
    NY
    kbreeden - you seem to be really knowledgeable and helpful regarding this skin. Do you have any thoughts on the questions I posted in 646?
  7. #657
    Jun 2002
    Virginia
    Quote Originally Posted by ckny View Post
    Well, I don't know how knowledgeable I am, but I'll tell you what I know. I use XM and had the very same issue with XM a while back. I recall John doing some kind of a fix that solved the problem. I use the blue skin. The blue skin has been the flagship of DigitalFX and my sense from reading through the posts is that blue is the most up-to-date. If I were you I would try Sirius with the blue and see if it works. If so, the issue is peculiar to the copper skin. If not, it it related to the Sirius skin in general. Please post the result so John will know how to address the issue.
  8. #658
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Anyone using RREarth skins in FX Blue?
    I can't seem to get it working.
    Using the RR beta (not tonight's release)
    registered RREarth.dll
    The FX blue RREarth skin opens up, but google earth never opens. It opens ok when I run it outside RR
    Any help would be appreciated.
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
  9. #659
    Dec 2005
    Peg, Canada
    Quote Originally Posted by JohnWPB View Post
    Ok, I've looked back quite a few pages and no sign of adjusting autoexec.tbl, even tried a search for autoexec.tbl and all it found was this instance.
    I think I have getting extra copies of iguidance popping up and it'd be nice to stop the clones before they overrun the system
    Great new skin BTW, just rebuilt the car computer and it's a perfect addition.
    Sky
  10. #660
    Dec 2006
    Treetop - try extracting all the files in the ZIP to a temp directory and then running the installer.
    Or read the included help file and follow the manual install process. It isn't difficult or that many steps.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
