I did everything the install instructions said but RR keeps saying its not a valid skin. What could be up?
MapPoint
Destinator
Streets & Trips
Other
Manual install worked! I had read the manual but it wasn't obvious where the skin folder was; i found it within Roadrunner>skins.
Works like a charm. Thanks.![]()
I am using RadioShark and the AM/FM Button isn't working at all for me. The only way I can change between the 2 is close RoadRunner, open the RadioShark software and change, then open RoadRunner back up.
I just did some research, and as far as I can tell the skin is correct according to Evolution VIII's instructions from THIS POST.
Here is the command in the DigitalFX Radio_Player.skin:BUTTONS
"RADIOBAND" - Change AM/FM
So all looks well, according to his commands/instructions. All I can suggest is to PM Evolution and see what he has to say about it.B,115,201,93,75,"RADIOBAND",
My Fiero Build Thread
LOL You're probably making the same mistake i made at first..do this:
After you unpack the archive, look for folder called "Road Runner", open it then find folder "skins", open it and there it is! (in my case called DigitalFXRed") THAT's the folder you are supposed to copy to the RR skin folder. You'll know it's the right one if you open it and it has the all the jpg's that make up the skin..
as of now i am having 2 major issues.
i cant get iguidance to embed itself into RR, ive patched it with the file on the website also. It just keeps opening a regular window.
second i cant get the picture to change on the front screen, ive added *.exe to the file types and still no go. is there any plugin or extra that i need installed? new version of directx? etc.?
any help would be great.
I posted in that other thread, thanks John. Hopefully I can figure something out. Does the button work for you?
I solved the issue with the RadioShark. If anyone else is having the same problem you need to install the lastest version from Griffin's Website and then apply the patch from the thread John posted earlier.
would it be possiable to have the mappoint route planner screens in street and trips.
what happens at the monent is this :
screen before route planner
and when i press route planner
Basically i'm after the osk to type in the route planner box on picture 2
also what skin do i change for the audio gps button to load my gps in player window ,what should i replace the line with
I am having trouble integrating my Valentine One with DigitalFX. I have my V1 working properly with SoftwareOne using the ttl2usb box. I saw in the skin folder there is a valentine.skin file and associated graphics. I have not been able to pull up that screen. I've read this entire thread and I don't recall anybody mentioning using their V1 with this skin. Is anybody using their V1 with DigitalFX? How do I access the Valentine menu?
Tom
