Thanks. At least now I know that it's a hardware issue. It works fine on my two desktops, but not on my carputer. I should be able to sort it out from here.
Printable View
Since you said the video disabling skin is finished I guess I should mention that it should say "In" instead of "on." Also, for the sake of consistency you may want to capitalize the "V" in "Vehicle."
Good Catch! All fixed, and image above is also fixed. (Not bad, 7 minute response time on that one :) )
I found that the Restart song button was not working and the progress indicator is missing.
Fixed it by editing the skin file. The restart song button was actually mapped to repeat.
Jarred
Again, this skin is off the hook!
That is odd, I just checked and the "Restart Song" button is correct in the skin here, and has not been touched in a LONG time. Are you downloading the version form johnwpb.com?
I am in the middle of a MAJOR project involving power tools :D
I am sick of the computer just being in the hatch back sitting there. I am building a custom box for it. It is a ROYAL pain, as it can't be simple and just be a plain square box. The way my hatchback area is designed is with all sort of curves, and the top of the box is a completely different size and shape than the bottom of it. It is a definite challenge trying to pull this one off!
I am taking photo's throughout the project, and will post them on my site (When I get the project and the website completed). This will also give me a place to mount and install my amp. Hahaha The amp has been in a box since Christmas..... LAST Christmas 05! Me procrastinate? Never!
Thank you for adding the .ini file to address non-c: partition installations.
This morning's download worked fine except for this hang on two different computers:
Line: 202
Char: 10
Error: File not found
Code: 800A0035
Source: Microsoft VisualBasicScript runtime error.
I commented out the following lines and the install ran to completion:
objFSO.CopyFile "motionlock.dll" ,RRPath, OverWriteFiles
objFSO.CopyFile "motionlock.ini" ,RRPath, OverWriteFiles
i just had a quick question. i love the skin and i in particular like the playlist functions (save load rename etc.). anyway, i am trying to use your scripts (sry). my problem is that when i click on my load playlist button or save playlist button, the list it comes up with on the next screen is blank. however, if i restart RR and run your skin (not run my skin, then switch to yours, because i get the same problem) it works fine like it should. im thinking maybe a variable problem or something?
sry if this seems complicated, im really bad with words. basically, when i click on my save or load playlist buttons, the list is blank. but it works in your skin. im using the same coding and my playlists folder is in the same place as usual and i have manually defined it in the RR.ini like the help said. any suggestions?
