View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 8 of 376 FirstFirst 12345678910111213141516171858108 ... LastLast
Results 71 to 80 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #71
    Jun 2002
    Virginia
    Quote Originally Posted by JohnWPB View Post
    As for the mute indicators, I just went through EVERY screen, and I did find that it was not working on the applications menu (Fixed now). Other than that, it is working on all screens here. This is a hardware specific thing, based on what line you are using for audio ect. The indicator is for the Master Volume. If you are using wave volume or something else, and mute it, the audio will mute, but the mater mute is not activated, thus the indicator will not show. I have no way at all of testing this here, as both my machine and CarPC use the master mute.
    Thanks. At least now I know that it's a hardware issue. It works fine on my two desktops, but not on my carputer. I should be able to sort it out from here.
  2. #72
    Jun 2002
    Virginia
    Since you said the video disabling skin is finished I guess I should mention that it should say "In" instead of "on." Also, for the sake of consistency you may want to capitalize the "V" in "Vehicle."
  3. #73
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Good Catch! All fixed, and image above is also fixed. (Not bad, 7 minute response time on that one )
    My Fiero Build Thread
  4. #74
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    GPS Audio Skin
    I found that the Restart song button was not working and the progress indicator is missing.
    Fixed it by editing the skin file. The restart song button was actually mapped to repeat.
    Jarred
    Again, this skin is off the hook!
  5. #75
    Jun 2002
    Virginia
    Quote Originally Posted by jarred View Post
    That's interesting because restart works fine and progress indicator is present on all three of my machines.
  6. #76
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Restart Song Button
    Jarred
    That is odd, I just checked and the "Restart Song" button is correct in the skin here, and has not been touched in a LONG time. Are you downloading the version form johnwpb.com?
    I am in the middle of a MAJOR project involving power tools
    I am sick of the computer just being in the hatch back sitting there. I am building a custom box for it. It is a ROYAL pain, as it can't be simple and just be a plain square box. The way my hatchback area is designed is with all sort of curves, and the top of the box is a completely different size and shape than the bottom of it. It is a definite challenge trying to pull this one off!
    I am taking photo's throughout the project, and will post them on my site (When I get the project and the website completed). This will also give me a place to mount and install my amp. Hahaha The amp has been in a box since Christmas..... LAST Christmas 05! Me procrastinate? Never!
  7. #77
    May 2006
    Installer Hangs - File Not Found
    Thank you for adding the .ini file to address non-c: partition installations.
    This morning's download worked fine except for this hang on two different computers:
    Line: 202
    Char: 10
    Error: File not found
    Code: 800A0035
    Source: Microsoft VisualBasicScript runtime error.
    I commented out the following lines and the install ran to completion:
    objFSO.CopyFile "motionlock.dll" ,RRPath, OverWriteFiles
    objFSO.CopyFile "motionlock.ini" ,RRPath, OverWriteFiles
  8. #78
    Sep 2000
    Stockton, CA USA
    It was working on all skins, except the Audio GPS skin, that is the one I had to edit. This is the version I downloaded last night from Johnwpb.com.
  9. #79
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    i just had a quick question. i love the skin and i in particular like the playlist functions (save load rename etc.). anyway, i am trying to use your scripts (sry). my problem is that when i click on my load playlist button or save playlist button, the list it comes up with on the next screen is blank. however, if i restart RR and run your skin (not run my skin, then switch to yours, because i get the same problem) it works fine like it should. im thinking maybe a variable problem or something?
    sry if this seems complicated, im really bad with words. basically, when i click on my save or load playlist buttons, the list is blank. but it works in your skin. im using the same coding and my playlists folder is in the same place as usual and i have manually defined it in the RR.ini like the help said. any suggestions?
  10. #80
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    3) ODBII is next on my list of MAJOR items. It is going to be a little bit down the road though, as I have ye to get the hardware and such for testing. I plan on using the donations from the PayPal link for just that purpose. This way I get something, but it is something to make the skin better for everyone at the same time.
    I am really looking forward to that functionallity added. I can certainly test it for you if needed!
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
