View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 84 of 376 FirstFirst ... 34747576777879808182838485868788899091929394134184 ... LastLast
Results 831 to 840 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #831
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    I did the flash forced downgrade using the flash8.ocx file...
    Folowing this recent post by guino I am running the latest flash, v9.0.45.0 on integrated graphics (not ati as he states) with zero problems once I followed his suggestion.
    Something to try for those having problems grtting this wonderful skin 'up and running'
  2. #832
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by klundy View Post
    I am having the same problem as Ramanator in post http://www.mp3car.com/vbulletin/1048524-post788.html
    It works fine on my desktop machine - which is why I brought my carpc in.
    The rr.ini has been updated and only has one entry for fastmode=-1
    I tried both the 2.0 and the 2.1 from a couple of hours ago.
    Ideas?
    Wow, I have not see that happen here, so it is really hard to troubleshoot. Make sure you have the fastmode=-1 in the rr.ini file. Also make sure that you are using the latest Road Runner.exe from This Link
    My Fiero Build Thread
  3. #833
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    Quote Originally Posted by JohnWPB View Post
    Wow! What is the deal! I put the mirror up hoping that BOTH of the sites wouldn't go down at the same time.... I don't get it.
    When you say the main site is down, you mean JohnWPB.com, or the download links? I just checked and my site is up, and both DL links are working....
    I can't get to this site " http://www.johnwpb.com"
    To choose the download
  4. #834
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by mdlesk View Post
    John, I already use the digital clock with the compass at the bottom. I did the flash forced downgrade using the flash8.ocx file. I'm not sure why it was taking so long when I added the coding from the original Digital FX Skin.
    You mentioned you are using the compass at the bottom, the compass is a flash applet.
    Try this:
    With RR running, with the time and the digital compass, press CTRL-ALT-Del and see what your CPU usage is. If it is really high then:
    Try using the Digital Clock & Date (No flash is used then) , go back to the main menu and see if you have just the time at the top, a static logo in the center, and the date at the bottom, if so restart RR. Restart RR and see if things work more smoothly. Now look at the CPU usage, if it is lower, and the skin seems to be working better, it is definitely a flash problem in that case.
  5. #835
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Bump View Post
    Hmmm I have been checking it over the past 10 minutes after your post and it is coming up fine here, even clearing the cache, and then even in Internet Explorer (Yuck!).
    Is anyone else not seeing the JohnWPB.com site coming up? It must be working, as I can sit there and hit refresh, and see the numbers changing meaning someone is on the site clicking the download links. I would check and see if you have some sort of firewall, or something else preventing the site from loading for you.
    EDIT: I just checked the server logs, and see no outages or lapses in times between page views. It has to be some strange thing between your computer through your ISP to the site or something.
    Here is the direct link to the file on CarPCNet.com
  6. #836
    Nov 2004
    Chambersburg, PA
    Ideas?
    Do you have this line in RR.ini ?
    picspath=C:\Program Files\Road Runner\skins\DigitalFX 2.0\Backgrounds
    I can cause it to do the same screen if :
    1. no , " picspath=C:\Program Files\Road Runner\skins\DigitalFX 2.0\Backgrounds "
    2. no , Fastmode=-1
    3. no, rr.ini
    I'll see if I can delete some other stuff to cause it.
  7. #837
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Ideas?
    I was messing with rr.ini and after i was done and tryed to run DFX, i got that black bar.
    Run the installer again and it will be fixed.
  8. #838
    Nov 2004
    Chambersburg, PA
    I can't get to your domain. i tried firefox and IE
    it might just be my crappy DNS servers are F*** again.
    oh well, I'll try my Proxy account.
    thanks any way.
  9. #839
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    I noticed when I downloaded the 2.1 that the file name is still named "DigitalFX2.0 Installer." Is this correct?
    Thanks,
    Jarred
  10. #840
    Jan 2007
    Columbus, OH
    I was able to get to the site without any issues, whatsoever.
    John, I just went out and looked at it, I was wrong. Since upgrading to 2.0, I was using the time at the top, mustang logo in center, and date at the bottom. I just installed the newly updated 2.1, but when I load RoadRunner, it's at 100% Usage and I can't do anything. The logo is like a moving moon. For the moment I went back to DigitalFx 1 until I can figure out what is going on with 2.1 or just reinstall 2.0. Digital FX V.1 is so much quicker than 2.0, but I have the lack of color schemes. Hopefully I'll figure something out to accomodate a little of each.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
