View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 87 of 376 FirstFirst ... 37777879808182838485868788899091929394959697137187 ... LastLast
Results 861 to 870 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #861
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Use the double pipes || to run the second program.
    RUN;First Program||RUN;Second Program
  2. #862
    Jan 2007
    Columbus, OH
    Okay, thanks. It it just a double pipe or a space in between the 2?
  3. #863
    Dec 2006
    BROOKLYN NY
    Okay, when I loaded RR, 2.1 nothing happened it stayed at 100% cpu load and if I tried to touch any of the buttons nothing happen..am i going something wrong....
  4. #864
    Jan 2007
    Columbus, OH
    shot598, welcome to the club lol. I have yet to figure out a solution. I am guessing it is a flash issue. I'm working on a workaround.
  5. #865
    Dec 2006
    Quote Originally Posted by JohnWPB View Post
    03/01/2007?!?! Is that the one that I included with the installer???? I hope not, or this is as much my fault! You need the 04/11/07 RR Located HERE
    Give that a try and see if that fixes the problem.. (Fingers crossed)
    EDIT: After a momentary panic attack, I checked the install file, and the version packaged is the 4/11/07 version. I am not sure how you still have the 03/01/07 version if you copied that one from the desktop that the installer put there, to your RR folder.
    Well the problem is resolved, but I don't know what the issue was. Since everyone kept talking about rr.ini, I decided to copy the rr.ini from the working desktop to the nonworking laptop. Started up like a champ.
    So that told me that it was likely to be some line in rr.ini. I went through each line, one by one, adding from the old ini to the functioning ini. I finished every line and never had a failure.
    So then thinking maybe there was some corruption, strange character in the ini file that was not displaying in notepad, but wrecking havoc with rr. I copied the original full rr.ini back. I expected a failure. But no, it worked.
    Bizarre. It's almost like something in my rr.ini was not letting your skin initialize for the first time, but once your skin had done it's initial startup, it continued to work.
    So I guess it's not problem solved, but problem avoided
    Did anything change in the .skin files? I had added some extra indicators and lables to several sreens. Can I just copy over the skin files, or do I need to cut/paste my additions?
    I second/third the request to have a page with customizable buttons! Or maybe you could consider releasing the psd for a blank template page so we could customize and include icons (I don't think you can include icons via a lable command can you?)
    Anyway, thanks for the great work and congrats on the the first out of the gate with a transparant skin!
    Kevin
  6. #866
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    John , If people are having problems with install , flash.
    Can you redo your installer so that the first time you start the skin . Your new 3d flash(clocks,calendar,clock moon,.. ) it not a default. Because , I can see how it would cause problems with not updated flash, small memory, or low speed cpu systems.
    But, if the default was just the normal setup like 2.0 version. you know it worked.
    If people want to change it to 3d version and get lock up. They can just reinstall the installer and be back to default with out the 3d flash.
    I think it would same a lot of trouble with other installs that are not updated flash, small memory, or low speed cpu systems. That are crashing & locked up.
  7. #867
    Jan 2007
    Columbus, OH
    Yeah, I've been trying to find a config file with default 3d logo and try to change it but with no luck
  8. #868
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    John, back in post#825 ("mine") I was tring to show you my "RR.ini" file, My file was named diffrently; but the pic didnt host so im tring again, also in post#819 I had mentioned that (after "EDITING") The problem was fixed on my end thanx to Bump. I had 2 Fastmode codes installed.I had to delete the "Fastmode=1" code. It even fix my "weather icon" issues i had awhile back.
    Thanx guys.
    If you cant DODGE em, RAM em.
  9. #869
    Jul 2005
    How do you setup the weather display for the uk ?
  10. #870
    Dec 2006
    labels don't work
    John, or anyone else -
    Any thought why these labels would work under FX Blue, but will not work under FX 2.0?
    L,470,10,50,23,255,255,255,12,"Arial:B","BATTPERCE NT","LEFT"
    L,295,10,70,23,255,255,255,12,"Arial:B","POWERSRC" ,"LEFT"
    I have these on my main menu.skin. I also have
    L,650,290,50,23,255,255,255,16,"Arial:B","GPSSAT", "CENTER" which puts the current satellite count in the middle of the GPS button. That one works. I did that because I had a problem with xport at one time and this was a quick way to see if it was working, then I liked it. No use to load IG if no satellites.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
