MapPoint
Destinator
Streets & Trips
Other
Don't feel bad, it happens to everyone. I'm having a similar problem. Everytime I boot I get an iguidance error and I just choose don't send. It's getting kind of annoying. I have alerter turned off along with tons of other services, I know there is a simple solution. I just can't seem to remember it in now though![]()
that won't work for several reason, one of which I don't boot into explorer and even when I try to run explorer it only opens up the explorer window, no desktop, no start, no taskbar, nothing. I use RR as the front end and it works good except that I get that iguidance error on load
Well, I am still seeing the delays even with Flash 8 and a non-flash setup in DFX 2.0. But...I only saw the delay when the GPS system within RR/DFX was trying to get a satellite fix (to do the speed adjusted volume). Once the speed was determined, things worked OK.
This problem is really bad up here in the northeast right now with such heavy cloud cover for both GPS and XM signals. I loose the signals very easily. Could this sort of thing help explain why some are seeing the problem and others aren't?
I thought it was fixed with 2.0 version
in your skin Check your " ExecTBL.ini" file
see if you have :
If so , replace it with this one:Code:/"ONSKINSTART","RUNQW;$SkinPath$Scripts\OnlineStatus.exe||RUNQ;$gpspath$|NOWARNING"
Code:/"ONSKINSTART","RUNQW;$SkinPath$Scripts\OnlineStatus.exe"
that was the fix for the older version.
I'll look into it a little more.
Thanks, that has to be it since it only started after I went from 2.0 to 1.0 blue. I'm going to give that a shot. If it doesn't work I'll just reinstall the first release of 2.0.
