View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 90 of 376 FirstFirst ... 408081828384858687888990919293949596979899100140190 ... LastLast
Results 891 to 900 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #891
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    John new update is cool but the flash cause my system to go to 100% on cpu power. And i am trying to fix out how u change to non flash but its stuck on 100% on my cpu. Can you make it where it doesn't go to flash in the beginning when we install. My MII12000 can't take it.
  2. #892
    Jan 2007
    Columbus, OH
    John, okay I tried the changing the gauges and it still remained way off. When I open up RR.ini it is showing it's MPH but it's still reading 105 at 65.
  3. #893
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    Quote Originally Posted by mdlesk View Post
    look in RR.INI
    look for
    Code:
    isunits=true
    change it to
    Code:
     isunits=false
    that will change the settings to MPH
    true = KPH
    false = MPH
  4. #894
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by tn6478 View Post
    Yea, I learned my lesson! ALL future updates will default to a non flash screen! In the mean time open the DigitalFX skin folder, then the MENU folder. Double click the Photo.exe file. This will manually copy the non flash skin into the main skin folder.
    On a side note, its not your MII12000 board that can't handle it, you have a Flash problem. I just built a CarPC for a friend with that same exact board and it worked fine.
    My Fiero Build Thread
  5. #895
    Dec 2006
    BROOKLYN NY
    Okay, when I loaded RR, 2.1 nothing happened it stayed at 100% cpu load and if I tried to touch any of the buttons nothing happen.do i have a flash problem...
  6. #896
    Nov 2004
    Chambersburg, PA
    John what version flash are you using?
  7. #897
    Nov 2004
    Chambersburg, PA
    Quote Originally Posted by shot598 View Post
    read john's last post
  8. #898
    Jan 2007
    Columbus, OH
    Okay, the "isunits=false" worked. The line wasn't in the file at all so I added it at the bottom and everything is good now.
  9. #899
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    CPU at 100% PLEASE HELP!
    Yes, it is a flash problem. There is NOTHING I can do here to correct that unfortunately. It is on a per system basis
    [BEGIN RANT]
    Guys, I have posted multiple times:
    If the skin is very slugish, or does not respond at all:
    Go into the DigitalFX skin folder, then into the "MENU" sub-folder. Double click on the icon for Photo.exe. Then Start Road Runner and see if it works ok then.
    I have posted this about 4 times now I think. Someone PLEASE try this and tell me if that fixes the CPU issue.
    Mdesk, you were saying it was locked at 100% CPU, then you were talking about other issues, did the CPU issue clear up? SOMEONE HAVING THIS PROBLEM, PLEASE TRY THAT AND LET ME KNOW. This is the only way I can narrow the problem down.
    Sorry, I am just getting a bit frustrated is all, 4 pages of CPU at 100%, and not a single reply as to if following the above instructions work or not.
    My next step will be to remove ALL flash from the skin, gauges, clocks, the compass ect ect....
    [/END RANT]
    I am not upset, or mad in any way and I am not pointing the finger at anyone here. I just want to determine if the above instructions in small red pring fixes the problem. Anyhow, any one with this problem, will hopefully notice the text above when skimming the thread
  10. #900
    Mar 2007
    Nashua, NH
    Well, as I have mentioned earlier, my 19-second delay soemwhat comes and goes. I tried running Photo.exe in the skins folder and started up RR/DFX about 7 times with no delays. BUT, I wasn't seeing any delays earlier today either.
    But I will say this...I am not seeing any random pauses while using RR. Before I was. For example, while switching to XM from MP3, I would get a pause that would last sometimes up to 45 seconds. Sound would continue, but the UI was frozen or I'd get the Windows error sound effect.
    I went into Weather (did an update) and I did see a freeze. I had to reboot. Also, is Rip CD working yet? Cause it's not in my setup. When I click on rip cd, I just get a loooonnnnnggg pause...then nothing.
    Gas price finder was working...although the date was off by a week. The time was right though!
    Sorry I didn't have more definitive data...
    Steve
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
